what to do ?
- zirafin
Re: what to do ?
17 Mar 2016 00:43 - 17 Mar 2016 00:58
tensioners turned away, took off valve panel. Rotate until I saw ex and z / 5, but z / 5 is below the instructions .And do not know the correct standing shafts. and the ignition is standing on T Mark
Attachment IMAG1246.jpg not found
Attachment IMAG1286.jpg not found
Attachment IMAG1287.jpg not found
Attachment IMAG1288.jpg not found
Attachment IMAG1289.jpg not found
Attachment IMAG1290.jpg not found
Last edit: 17 Mar 2016 00:58 by zirafin.
- zirafin
Re: what to do ?
17 Mar 2016 05:20 - 17 Mar 2016 05:21
my problems dont end my time chain tensioner broken ;( no i nead to find it and buy it i dind use so big force to turn and its fall off fck. :S
Attachment IMAG1303.jpg not found
Last edit: 17 Mar 2016 05:21 by zirafin.
- loudhvx
Re: what to do ?
17 Mar 2016 08:41 - 17 Mar 2016 08:43
The cam timing looks ok. But difficult to say for sure in the photos.
I can't believe that broke like that. It's a very strong casting, usually.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 17 Mar 2016 08:43 by loudhvx.
- wrenchmonkey
Re: what to do ?
17 Mar 2016 10:14
Zirafin, can you list your location in your profile? We can gather you are in Europe somewhere because you said a cost in euro's.
If you can list your general location (ie: Italy or Germany etc) then you may find another member here close by who could possibly help you and avoid confusion of language translations.
The reason you cannot see the cam chain numbers is ( haha, I learned this one just a few weeks ago from loudhvx ) the cam chain needs to be gently pressed downward between the exhaust and intake cam gears (this is what happens when you bolt-on the valve cover). This will cause the rearward intake cam gear to rotate forward a little and the z/5 line should become visible like shown in the drawings. Then you count the chain link pins back to see it is between 43/44 pins.
I hope you can find someone here that lives close to you. Much of what you want to do is easy enough if another person can explain it in your native language.
The following user(s) said Thank You: zirafin
- zirafin
Re: what to do ?
17 Mar 2016 11:28
this cam tension was so tide app , It was very difficult to unscrew, but when moved just dropped the feeling that had already crashed before it ,driven to the Metalworkers, they will try to drill and renew the threads.
i am from lithuania.
- zirafin
Re: what to do ?
17 Mar 2016 11:34 - 17 Mar 2016 11:36Attachment IMAG.jpg not found
its looks like this if i push on center
Last edit: 17 Mar 2016 11:36 by zirafin.
- loudhvx
Re: what to do ?
17 Mar 2016 13:56
Now you count the pins like in the diagram.
1981 KZ550 D1 gpz.
Other links.
Other links.
- zirafin
Re: what to do ?
17 Mar 2016 23:33
it s looks ok. 43-44 pin .
ignition coil ?how to connect wires ( green ,black, yellow red x 2) in yellow red is 12 v and on ignition coil is + and - but in manual its says :
a. The green wire goes to left coil and the black wire goes to right coil.The yellow/red wires go to either the negative (-) or the positive (+) coil terminal.
- zirafin
Re: what to do ?
17 Mar 2016 23:55
ok i find my self
There is no difference on + ore on -.
my post need to move from forum carburetor to all .
There is no difference on + ore on -.my post need to move from forum carburetor to all .
- zirafin
Re: what to do ?
18 Mar 2016 07:04
metalworking was ok i hope tomorrow to test
23 euro
its new cost 25 euro but to wait 3 weeks ant pay for post 15 euro
. i hope its ok
23 euro Attachment IMAG1306.jpg not found
. i hope its ok
Re: what to do ?
18 Mar 2016 07:08
That'll work. Good job.
- wrenchmonkey
Re: what to do ?
18 Mar 2016 07:19
God Bless the machine shop guys!
They have saved my bacon more than once or a dozen times!
A good machinist is worth his weight in brass, titanium and cold rolled steel any day
