what to do ?
- zirafin
Re: what to do ?
30 May 2016 08:13 - 30 May 2016 08:16
halo
so i am still waiting for the parts. but still i have time to make my own paper seat for may future project on kz550 its only left to go to metalworkers
and explain it after adjust ,re cut ,to fit nice and then paint .
and explain it after adjust ,re cut ,to fit nice and then paint .Attachment IMAG1469.jpg not found
Attachment IMAG1472.jpg not found
Attachment IMAG1470.jpg not found
Last edit: 30 May 2016 08:16 by zirafin.
- zirafin
Re: what to do ?
03 Jun 2016 07:10
halo
today i get shims from germany , i install them and after all valve clearance was: ex all 4 - 0.20mm .IN all 4- 0.15 mm
i start the engine and on choke on all 4 cylinder are working and water test is good. but throttle grip is not working ;( so i tace carburator repair kit change all jets and other parts . but its same not working throttle grip next weak try to get compression tester ( my was broken) after i use on hot engine first cylinder was 145 psi o the second is have broken ,the rubber in the end just melt and rip. but i fink its will be good compression in all cylinders. so wat next wat u fink can be ????? fire timing ??? i do not know wat to do i start to fink i spend to mach euro for this kawasaky .
- The_Proletariat
- "Cocaine is a hell of a drug"
Re: what to do ?
03 Jun 2016 10:54zirafin wrote: halo
The only time my 550 dies as soon as I move the throttle grip off idle is when the engine is very cold, or if it is running very lean.
Before you drill any jets, put the needle clip on the 3rd position and see if the throttle grip works.
1982 Kawasaki KZ550 LTD
- zirafin
Re: what to do ?
03 Jun 2016 11:21
but if i use on 3 clip it will go more fuel ????
i will try it, thanks for advice.
- The_Proletariat
Re: what to do ?
03 Jun 2016 11:26zirafin wrote: but if i use on 3 clip it will go more fuel ????
Yes, this will add more fuel.
- zirafin
Re: what to do ?
03 Jun 2016 11:28
and my petcoc is broken again . if use on PRi posicion i need to close vacum port in petcoc and from carburetor vacum line i need to close to>>???
- The_Proletariat
Re: what to do ?
03 Jun 2016 11:41 - 03 Jun 2016 11:42zirafin wrote: and my petcoc is broken again . if use on PRi posicion i need to close vacum port in petcoc and from carburetor vacum line i need to close to>>???
Yes. Close/clog/plug the carburetor vacuum line. I filled in this port on carb #4 with epoxy (glue).
As long as this is done the petcock vacuum port can be left bare.
When you are not running the bike turn the petcock to "ON" to turn off fuel.
Last edit: 03 Jun 2016 11:42 by The_Proletariat.
The following user(s) said Thank You: zirafin
- zirafin
Re: what to do ?
03 Jun 2016 11:49
so tomorrow its again carburetor disassembling .
i start to fink if i use pods instead of air box , its coming more air then fuel so maybe its will be good to put the needle clip on the 3rd position .
can u write how much air screw must be turn out if i change needle position. now i was using 2.5 turn out .
- The_Proletariat
Re: what to do ?
03 Jun 2016 12:00 - 03 Jun 2016 12:01zirafin wrote: so tomorrow its again carburetor disassembling .
Yes you need more fuel with pods.
2.5 turns out is far too much. You should range between 1 - 1.5 turns out. Turn in the air screw to add fuel.
Before you change the needle clip set the air screws to 1 turn out. See what happens.
Last edit: 03 Jun 2016 12:01 by The_Proletariat.
- zirafin
- zirafin
Re: what to do ?
04 Jun 2016 08:21
so 1 turn is same
and i change needle to 3 clip its same its lets little to use accelerator handle
its all in video and u can see if choke is on cylinder 4 is ok if choke off cylinder 4 is not working so i am back to firs my post iI have done nothing to get better...... not working cylinder 4 and throttle grip...
- The_Proletariat
Re: what to do ?
04 Jun 2016 11:26 - 04 Jun 2016 11:32zirafin wrote: so 1 turn is same
I have no sound on work computer so I can't comment on the video.
The compression tester you have (rubber tipped, held against spark plug hole) will not work on a hot engine as you discovered. To test hot compression you need a gauge with adapters that screw into the spark plug holes. I could not find one to rent with the proper adapter in my area.
Besides that, I am not sure what to check. You have ran quite a few tests. Maybe some more experienced members will have other ideas.
How warm is the engine before you use the throttle? How warm is the ambient temperature outside? My 550 will die with the throttle until it is at least somewhat warmed up. Do you have all the choke flaps? Are the vacuum ports on the carb holders plugged?
If I was you, I would leave needle clip at 3rd position, make a manometer and sync the carbs for equal vacuum and set air screws for highest idle and see what happens. These 550's run terrible if the carbs are out of sync and can give the appearance of a weak cylinder.
Last edit: 04 Jun 2016 11:32 by The_Proletariat.
