- Thank you received: 1616
what to do ?
- loudhvx
Please confirm how you did the compression test. Did you do what Ed said?650ed wrote: You may not have tested the compression properly. To do so :
The engine must be warmed up to normal operating temperature. The pistons taper in near the top so with the engine warmed up they expand near the top which helps the rings seal against the cylinder walls.
The battery needs to be fully charged.
The throttle needs to be held all the way open.
All spark plugs must be removed.
If you do all that and compression is still low you should perform a leak down test. That will identify where the compression is leaking (could be valves, rings, head gasket, etc.) If you remove the cylinder head before performing the leak down test you will have lost the opportunity to use that diagnostic tool.
Does your compression gauge have a check valve in the tip? If not, that will cause low readings.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- loudhvx
I don't really want to repeat the service manual on my site. But my site does show the gasket.
1981 KZ550 D1 gpz.
Other links.
- zirafin
and gasket is on picture but not all can see special me
- zirafin
- loudhvx
Did you do that?
1981 KZ550 D1 gpz.
Other links.
- zirafin
Attachment index.jpeg not found
- loudhvx
yes.zirafin wrote: ok so it not enough to use choke on . ok i will try to throttle go all open ( i hope i understand u its throttle-in picture)
Choke open all the way.
Throttle open all the way.
1981 KZ550 D1 gpz.
Other links.
- zirafin
carbs its ok all parts is in.
valve clearance : picture . i turn using 17 wrench each valve lift up and test .
Attachment IMAG1456.jpg not found
Attachment IMAG1450.jpg not found
Attachment IMAG1455.jpg not found
Attachment IMAG1452.jpg not found
- zirafin
- zirafin
Attachment IMAG1457.jpg not found
- zirafin
from manual valve clearance its
ex 0.15-0.25mm
in 0.10-0.20 mm
Attachment IMAG1460.jpg not found
so if i want new shims to mace at metalworkers
i do :
1. 0.15mm is valve clearance i need to have 0,20 mm
0.20-0.15=0.05 mm
shim is standing under cup 2.44 mm
2.44-0.05=2.39mm2.38mm
so i need to make 2.39 mm 2.38 mm shim
next shims i have on paper :
Attachment IMAG1462.jpg not found
its ok o i need others shims o i can grind shims at metalworkers???
