- Thank you received: 1
what to do ?
- zirafin
and i I spoke on the phone with MECHANIC after i told what i was doing hi ask if i have vacuum in my carbs going to gas tank???
i know there is 1 line going from carburetor til gas tank.how to test this line and ho to test petcock on gas tank if is working on vacuum?
in this picture its : manifold vacuum route to petcock.
gpzweb.s3-website-us-east-1.amazonaws.co...Page/TK22hornEnd.jpg
- zirafin
on PRI position its will go if engine is running ore not
and i finking to test carburetor.maybe to close gas line, and to suck air thru vacuum line if its holt is working>??????
its good finking ore not>??
- The_Proletariat
- "Cocaine is a hell of a drug"
- Thank you received: 13
ok i found in manual that petcock can test remove the vacuum line and gas line on position ON ore RES , gas dont go out ,and if running engine provides vacuum and operate the diaphragm valve = so its start run gas ??
Correct. In the picture the hose "manifold vacuum route to petcock" needs to be plugged if you disconnect it from the petcock.
on pri position its will go if engine is running ore not
Correct.
If you suck on the vacuum line fuel should flow with the petcock in "On" or "Res" position.
To disable the petcock vacuum function, plug the vacuum line or nipple on the carb, and use "PRI" while the engine is running.
Too little fuel supply from the petcock will affect all your carbs/cylinders, not just one.
1982 Kawasaki KZ550 LTD
- loudhvx
- Thank you received: 1616
The compression values are very low. Normally, even on an old engine, I see about 170 to 180 psi.
Are you sure you had the throttle held wide open? (Choke fully off.)
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- zirafin
i test cold engine ,choke of: 125 psi and 4 cylinder is 150 psi.
i will wait for monday to show my kz to mechanic we will sea what will go i hope to hear the heart beats.
- zirafin
- Thank you received: 2829
The engine must be warmed up to normal operating temperature. The pistons taper in near the top so with the engine warmed up they expand near the top which helps the rings seal against the cylinder walls.
The battery needs to be fully charged.
The throttle needs to be held all the way open.
All spark plugs must be removed.
If you do all that and compression is still low you should perform a leak down test. That will identify where the compression is leaking (could be valves, rings, head gasket, etc.) If you remove the cylinder head before performing the leak down test you will have lost the opportunity to use that diagnostic tool.
- zirafin
so mechanic was to look my kz and ;
( the mechanic closed air in, on side of 4 carburetor (air filter) using hand its star work 4 cylinder ,and same time his hand was all in fuel )
1.like i finked the fuel is going to mach from carburetor , so firs its need synchronize carburetor work
2. the petcock is not holding vacuum .
3. and mechanic did not like the start ant shat up engine sounds, its says: its like not in timing,
its really going to mach fuel in to engine and its just stop working using the throttle grip.
after 3 days hi will try to synchronize carburetors and we will sea what is going on next,
the valve clearance to look will be next job .
- zirafin
cleaned again carburetors and now u can sea in video how its working 4 cylinder using choke and towel. but its still not working th throttle gripe .
- The_Proletariat
zirafin wrote: hi
You should check the valve clearance before you synchronize the carbs. Valve clearance will affect the carb sync.
How long was the engine running before you took this video?
- zirafin
www.kawasaki.com/Parts/PartsDiagram/134934/1981/KZ550-A2
i look in carburetor manual of kawasaki part page : and i think in my carburetor is missing o rings on needle jet so tomorrow i again tace a part of carburetor to look and i fink is missing some :gasket flout valve.
and if It appears to be true maybe it will be all problem on carbs.
- zirafin
i will try to mace more pictures
i hope the loudhvx dont be angry on my but hi can write in his carburetor page that its need and good idea to check if all o rings and gaskets is in carburetor, like if u buy carburetor kit for repair . where is still many "lol" like me unable to see the differences .then u open first time carburetor.
