what to do ?
- loudhvx
Re: what to do ?
25 Mar 2016 08:21
That is the factory setting on the factory needle, so it seems original.
I doubt you should start messing with jetting. It is not time to do that yet. Ignition seems more urgent.
I did not see the water test on the video.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- zirafin
Re: what to do ?
26 Mar 2016 08:53 - 26 Mar 2016 09:33
hi i have no time to mace video , i just tace off ignition coils and tested the wires its resistance 4.72 om but how to test ignition coil using multimeter? on coil is + and -
and ho to test ignition pickup coil .i will try tomorrow to mace video of water test
if u can give pictures and readings of what i need to see in multimeter.
Attachment IMAG1343.jpg not found
Attachment IMAG1339.jpg not found
Last edit: 26 Mar 2016 09:33 by zirafin.
- zirafin
Re: what to do ?
26 Mar 2016 11:55
power 12.5 v is til coils .
one more pic of test coil
Attachment IMAG1344.jpg not found
- zirafin
Re: what to do ?
27 Mar 2016 02:20It's water test 4 cilinder do not working . ;(
I swap spark plug I test resistor on ignition coils it's same but don't work.
- loudhvx
Re: what to do ?
27 Mar 2016 06:35 - 27 Mar 2016 06:48
No eBay APP ID and/or Cert ID defined in Kunena configurationIs the choke on in that video?
Was the choke flap missing, then replaced on #4?
Did # 4 have the weak red spark?
I think I would get new coils at this point.
I don't know if he ships to Lithuania. This one is for cylinders 2 and 3, but I would also get all new wires and caps. I like suppression wire instead of resistor caps.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 27 Mar 2016 06:48 by loudhvx.
Re: what to do ?
27 Mar 2016 07:45
Sounds way out of sync. That could account for #4 not keeping up with the others.
- zirafin
Re: what to do ?
27 Mar 2016 08:28
hi it was choke off .
yes it was flaps broken not missing, then i replaced 1 and 4 cilinder.
all cilinder have same weak red spark.
i tomorrow go to norway for a job . i will come home after 7 weeks , then I can continue fixing the motocycle.
i will try to buy new coils and wire , and caps , i will try tomorow to change coils 1-4 to 2-3 and chek if is change using water test.
- loudhvx
Re: what to do ?
27 Mar 2016 10:02Good idea. Good luck with job.zirafin wrote: hi it was choke off .
1981 KZ550 D1 gpz.
Other links.
Other links.
- Jussumguy
Re: what to do ?
27 Mar 2016 21:59
Don't forget a compression test. Might have a tight intake valve on #4
- zirafin
Re: what to do ?
28 Mar 2016 01:23 - 28 Mar 2016 01:24
hi today i swap the coils and greenand black cable to test and it was same working if i do not swap ,
so its 4 cylinder is not working.
and i don't have a tester to test compression, i did it before 2 months its vas ok,(then my bice was not starting )
but i try today to put finger and hold then starter works , its just push a little away . all 4 cylinder works same . i will see after i return from norway .
Last edit: 28 Mar 2016 01:24 by zirafin.
- zirafin
Re: what to do ?
15 Apr 2016 12:02 - 15 Apr 2016 12:05
good evening
:laugh: :laugh:
tomorrow I should get from Germany New coils for may Z550 ( kz550)
and its left to wait for four weeks til i can test it
and if u are from the Europe u can buy from them www.biketeile-service.de/
I paid 69 euros for 2
this is really cheap .
:laugh: :laugh:
Attachment s-l300.jpg not found
Last edit: 15 Apr 2016 12:05 by zirafin.
- zirafin
Re: what to do ?
16 May 2016 09:05
hi i just instaled new coils and wires and its same . not working. so i think to look again into chain timing and top dead of 1 cillinder .
