what to do ?
  • TexasKZ
  • TexasKZ's Avatar
Re: what to do ?
25 May 2016 05:54
#728391
I see that #4 exhaust and #3 & #4 intake are right at the small end of the range. They will continue to get smaller as parts wear, so I recommend adjusting them closer to the middle or large end of the allowable range. It is generally better to have the gap near the maximum allowed rather than close to the minimum.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: what to do ?
25 May 2016 06:10
#728395
Do NOT grind the shims. Making them is NOT possible. If you can't get them from US suppliers then buy a set on eBay.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • TexasKZ
  • TexasKZ's Avatar
Re: what to do ?
25 May 2016 06:15
#728399
swest wrote: Do NOT grind the shims. Making them is NOT possible. If you can't get them from US suppliers then buy a set on eBay.
Shims have a hardened surface that will be damaged by grinding. Replacement shims of the proper thickness are the only way to go.
Re: what to do ?
25 May 2016 07:19
#728416
Do NOT grind the shims and do NOT use something that a metalworker makes! Doing that can wreck your engine. Just BUY the correct shims. Do you have a Kawasaki Service Manual? If so, take a look in it about shims. Mine is very specific about NOT grinding them (see image below). If you do not have a Kawasaki Service Manual you really need to buy one if you plan to do any work on your bike. Ed
Attachment 00003d-2-3-4-5-6-7-8-9-10-11-12.jpg not found
  • zirafin
  • zirafin's Avatar Topic Author
Re: what to do ?
25 May 2016 07:54 - 25 May 2016 08:03
#728424
ok i donot grind it just finking to buy all new from germany ,price is 8 euro per one valve shim.
can i just change places shims if its a better fit for example from 2 til 6 place?
i can buy shims 2.45 mm X 3 , and 2.60 x 1
and rest i can change places so i will save half price.
Last edit: 25 May 2016 08:03 by zirafin.
  • loudhvx
  • loudhvx's Avatar
Re: what to do ?
25 May 2016 08:19 - 25 May 2016 08:20
#728432
zirafin wrote: ok i donot grind it just finking to buy all new from germany ,price is 8 euro per one valve shim.
Yes you can swap shims.
Follow the manual on shim changes and measurements. It is explained in detail in the manual.
Links are in my signature to download manuals. Use the factory manual.
Last edit: 25 May 2016 08:20 by loudhvx.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: what to do ?
25 May 2016 08:21
#728433
That's what I do. Since 13 I'buy the shims I need and one or two extra. Now I have a full set. I always get the next size down as extras.
  • zirafin
Re: what to do ?
25 May 2016 10:33
#728474
so i buy 4 valve shims and carburetor repair kit x4. so next weak will be more work ;)
  • The_Proletariat
  • The_Proletariat's Avatar
  • "Cocaine is a hell of a drug"
Re: what to do ?
25 May 2016 11:09
#728480
zirafin wrote: so i buy 4 valve shims and carburetor repair kit x4. so next weak will be more work ;)
Why do you need carb kits?
1982 Kawasaki KZ550 LTD
  • zirafin
Re: what to do ?
25 May 2016 23:52
#728602
after i want to Drilling jets for using pods instead of air filter . so i want to have spare parts.if i fail.
  • The_Proletariat
Re: what to do ?
26 May 2016 14:00 - 26 May 2016 14:04
#728697
That may not be necessary. Loudhvx has information on his website about running pods with just a needle shim.
Last edit: 26 May 2016 14:04 by The_Proletariat.
