- Thank you received: 1
what to do ?
- zirafin
21 Mar 2016 09:40 #716531
by zirafin
Replied by zirafin on topic what to do ?
hi the metalworking is looks ok . today i putt back carbs and i looked at this video its helped me allot (t22 bench synch)
so i find my 2 choke flaps was broken , i made from copper plates and installed , just for now to test .now my moto. starts and then its worm is working choke off but still not working throttle grip. so today I picked up my air filter box ,and took out the rubber crossings between the carburetor and the air filter . the rubber crossings was so hard and shrink. not round, so i put in a bowl and filled hot water that recovers to the original position and soften.and tomorrow i will try to put in to place. and test again if my throttle grip working.
if not i need more tips :blush:
Attachment IMAG1314.jpg not found
- zirafin
21 Mar 2016 09:59 #716534
by zirafin
i filled water on the exhaust, all 4 exhaust was same hot .
i cleaned all 4 pilot jets ( 1 was dirty).
and then pod filter is on and i try to use throttle grip i can hear how carburetor Suck air and then engine shut down. so maybe it will help me after i will fix the air box in
- zirafin
23 Mar 2016 06:04 #716915
by zirafin
hi after this fck air filter box instal ,its working same but then i close the air filter top (u can sea in video) its lets a throttle grip to move and speed up .but if use more its just not works.
can u give a tip???
can u give a tip???
- Thank you received: 2829
23 Mar 2016 06:19 #716917
by 650ed
Replied by 650ed on topic what to do ?
Pardon me if this is a dumb question, but Is the air filter element fitted inside the air box? Ed
- zirafin
23 Mar 2016 06:22 #716918
by zirafin
yes
- KZB2 650
- Thank you received: 265
23 Mar 2016 06:37 #716919
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic what to do ?
Maybe I missed it but one of the top recommendations on here is oiling up the advancer and by the rust in the picture of it thinking you should add this to your list.
1978 KZ650 b-2
- loudhvx
- Thank you received: 1616
23 Mar 2016 08:46 #716935
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic what to do ?
Have you tried the water test on the exhaust to make sure you are running on 4 cylinders? The water should dance off of each pipe the same way.
1981 KZ550 D1 gpz.
Other links.
- zirafin
23 Mar 2016 08:57 #716937
by zirafin
yes i try ,all pipe are hot and then the engine is worm its boils and dance away . but i think maybe the spark is weak and is not good . tomorrow i will try to mace video of water
- loudhvx
23 Mar 2016 09:33 - 23 Mar 2016 09:34 #716947
by loudhvx
1981 KZ550 D1 gpz.
Other links.
Also, what is the needle clip setting?
Have you tried to open throttle while removing choke (both very slowly so it doesn't die)?
Even if the advancer was stuck at F, it should be able to get to 2000 RPM.
1981 KZ550 D1 gpz.
Other links.
Last edit: 23 Mar 2016 09:34 by loudhvx.
- zirafin
23 Mar 2016 10:46 - 23 Mar 2016 10:52 #716958
by zirafin
yes i try this its hols just a little. open throttle while removing choke.
no i do not no needle clip settings , because it was cleaning the other person.
i tested my spark plug is only 2 of 4 is working nice rest vas badly but i got red spark not blue:( video
and i tested cylinder 1 and 2 for spark.
Last edit: 23 Mar 2016 10:52 by zirafin.
- zirafin
24 Mar 2016 03:22 #717068
by zirafin
one mechanic say to check carburetor if the needles is closing float petrol?
if u know about it can u give me how to check???
- zirafin
25 Mar 2016 06:58 #717260
by zirafin
iam so sad and pist on my z550 its do not want to work so i tace away air box again and start to order drill bit for drilling the pilot jet and main jet.
i copy from forum this :
I would go from 32 idle jet to 37 idle jet.
Get adjustable needles and set them to 3rd or 4th clip from the top, and I'd start with 100 or 102 mains.
ok if i drill the pilot jet 37 , main jet at 99.1 and needles if adjust can my be adjust?
Attachment IMAG1333-2.jpg not found
