what to do ?
- The_Proletariat
- "Cocaine is a hell of a drug"
Re: what to do ?
04 Jun 2016 18:20
I would also check the fuel strainer on the petcock. That bike has been sitting for a while and there is probably debris in the gas tank.
Also I am not sure what kind of fuel you have in Europe but a paper fuel filter like that will clog quickly with the gasoline we have in the US.
1982 Kawasaki KZ550 LTD
- zirafin
Re: what to do ?
05 Jun 2016 05:50
hi today i make a manometer for carb. but first what i did before in all this post:
clean fuel tank, line, change the filter .
new spark plugs , buy new coil and cables.
clean carburetor, fix 2 choke flaps , change all jets , needles, lift the needle on clip 3.
no airbox. using pods.
valve clearance fixed using new shims.
and i make my very simple carburetor manometer . this video is after i adjust little .
but i will gen maybe on Tuesday normal manometer and mechanic to do synchronization. i will see that will be difference.
and is still then choke is of not working cylinder 4 and throttle grip.
Re: what to do ?
05 Jun 2016 05:57
Pics of plugs?
- zirafin
- zirafin
Re: what to do ?
05 Jun 2016 06:30 - 05 Jun 2016 06:33
4-3-2-1 spar plugs
1-2-3-4 spar plugs
1-2-3-4 spar plugs
Attachment IMAG1485.jpg not found
1-2-3-4 spar plugs
Attachment IMAG1489.jpg not found
1-2-3-4 spar plugs
Attachment IMAG1492.jpg not found
Last edit: 05 Jun 2016 06:33 by zirafin.
Re: what to do ?
05 Jun 2016 06:51
Looks like #3 is bridged and #4 is fouled. Have you tried cutting 1/4" off the spark plug leads to make better connections? Plug caps could be bad too.
- zirafin
Re: what to do ?
05 Jun 2016 07:08
its new spark plug leads (wires ) ,spark caps i can test next day, but i was changing places, so i don't fink that is a problem.
so way its not respond to throttle grip. more advises ??????
Re: what to do ?
05 Jun 2016 07:24
Broken cable?
- zirafin
- zirafin
Re: what to do ?
17 Jun 2016 05:45
so mechanic looked for 2 days . verdict is the engine is ok . the rest is crap . the ignition ,wiring, is bad and its will be the problem . so now this motorcycle i will frozen til i will get more euro and then try find parts for ignition and igniter.
maybe someone can write how to test ore video how you using multimeter on your kz550 to test ignition and igniter???
- KZB2 650
Re: what to do ?
18 Jun 2016 05:12
Check under loudhvx's profile on page 6 for the links he provides....... wish he owned a 650.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- zirafin
Re: what to do ?
18 Jun 2016 10:02
i found info on forum and in manual . its sparking if i use info from manual.
ing
and if i test pickup coils it 430 427 ohms
its left only to test pickup coils like in this video :
and if it past i give up my kz550 is cursed and i am buy other motorbike ;(
ing
Attachment icignitertest.jpg not found
