carb tune help/procedure
  • blink543
  • blink543's Avatar Topic Author
16 Jul 2015 10:55
#681136
I've been wondering why when I accelerate its kinda laggy and kinda sounds boggy when I open it all the way up.I was told it's probably the carbs. I've tuned them before but I probably did more bad than good. The gauges I used were in inches hg not cm hg like noted in the manual. I went online and converted the cm needed to inches and it said a little over 8 inches hg. So I did that but it's hard to keep it from revving and dealing with the idle screw too. What's the procedure in trying to balance them? Do I go in order carb 1-4?
Adam james
  • rctreadaway
  • rctreadaway's Avatar
Re: carb tune help/procedure
16 Jul 2015 12:05 - 16 Jul 2015 12:08
#681139
I would try bench syncing them first if you're having that much trouble. The main thing isn't the number, but that they're all even and moving together as closely as possible. i used a light looking through the carb and adjusted them down one at a time until the light was all but gone. Then put them on the bike and set the idle. It doesn't matter what order unless you have a lead carb. That would be the one without an adjuster. Just depends on your carbs. Mine all had adjusters so I just made sure they were all even.
I would check to make sure you're also getting good spark as well. The plugs in my bike were starting to foul when i purchased it.
1980 KZ1000 LTD -
CR Special Carbs/Kerker Exhaust/K&N Pods/Dyna Ign
'09 ZX6R Controls/Rearsets
'06 GSXR1000 Suspension (to be installed)
Last edit: 16 Jul 2015 12:08 by rctreadaway.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jul 2015 12:56
#681144
Chose one carb to be the lead carb and make to others the same as that one.
  • Zephyrrider
  • Zephyrrider's Avatar
16 Jul 2015 15:13 - 16 Jul 2015 15:14
#681155
blink - do not bother with the actual readings -
try and get them all within + or - 2 cmhg of each other (may be slightly different to mine )
what model is yours ?
What kind of manometers are you using ?
Mick
1994 ZR750 Zephyr C4.
Last edit: 16 Jul 2015 15:14 by Zephyrrider.
  • blink543
16 Jul 2015 18:44
#681185
rctreadaway wrote: I would try bench syncing them first if you're having that much trouble. The main thing isn't the number, but that they're all even and moving together as closely as possible. i used a light looking through the carb and adjusted them down one at a time until the light was all but gone. Then put them on the bike and set the idle. It doesn't matter what order unless you have a lead carb. That would be the one without an adjuster. Just depends on your carbs. Mine all had adjusters so I just made sure they were all even.
I forgot to mention it's a 78 kz650b. I adjust them by turning the air screw on top of the carbs? They're minuki carbs or however u say it.
Adam james
  • blink543
16 Jul 2015 18:45
#681186
Zephyrrider wrote: blink - do not bother with the actual readings -
A 78 kz650b. I was using vacuum gauges inches hg not cm hg
Adam james
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jul 2015 18:46
#681187
You don't have a manual do you?
16 Jul 2015 18:49
#681189
? :blink: ? If you have a manual go back and re-read through the section on synchronizing the carbs. You do NOT fiddle with the air screws to synchronize the carbs. The air screws have nothing whatsoever to do with carb synchronization. Ed
  • blink543
16 Jul 2015 19:13
#681194
They do. In the manual it says it's supposed to mess with the air to fuel mix. Then what does it do
Adam james
  • blink543
16 Jul 2015 19:26
#681196
Adam james
16 Jul 2015 19:50 - 16 Jul 2015 20:38
#681207
What manual are you using?? If it say to sync the carbs you are "supposed to mess with the air to fuel mix" throw the manual away and buy Kawasaki Service Manual. You do NOT fiddle with the air/fuel mixture to synchronize the carbs. You DO adjust the individual throttle adjusting screws to synchronize the carbs. However, if you have gotten the air screws out of adjustment by fiddling with them you will first need to undo whatever it is you did to them. Ed
Last edit: 16 Jul 2015 20:38 by 650ed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jul 2015 20:08
#681213
I'm going to sync my carbs soon. I'll do a thread on it. In the mean time get a manual.
