carb tune help/procedure
  • KZB2 650
  • KZB2 650's Avatar
Re: carb tune help/procedure
20 Jul 2015 16:13
#681874
Hope you are using the 17mm nut to turn it over and only going clockwise when turning it over........ I found the plunger on the tensioner was right at 15/16 to one inch out when my cam chain is tight (from the housing not the gasket)........ if its one inch and 5/16 or a hair more out you've pretty much reached its limit........ If your readings are thousands on the cam clearances your ok for a while.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
