Valve guide size
  • zed1015
  • zed1015's Avatar
Re: Valve guide size
10 Apr 2016 07:59 - 10 Apr 2016 08:00
#720170
bromz wrote: Well guys a 200 shim a valve stem ground and still no clearance!! Any last ditch ideas before I take it in to the machine shop??
There are a few things that can be done machining wise with your existing valves and retainers which I won't go into now but they are for someone who really knows what they are doing with these engines.
That aside the simple fix is to start by trying a new unworn valve (which may also need tipping) .
This may be enough to get the clearance back if your existing valve heads are worn or have been re-faced.
Failing that fitting 1mm larger valves is the usual bolt in solution.
This puts the valve face further out on the un-cut , un-worn portion of the seat and brings the stem height back down to the low end of the specs.
You can also use 'J' valves which also have a shorter stem if you were in the same situation but larger valves were already installed.
After this you are looking at having new seats fitted.
Last edit: 10 Apr 2016 08:00 by zed1015.
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Apr 2016 08:07 - 10 Apr 2016 08:08
#720172
Not just any repair shop can do these heads. Any heavy handed old time shop can do old style heads but these don't have the large tolerances they do. Even my old Ford 390 has a limited range. Once at that point, only new cintered valve seats will make the heads runable again.
Last edit: 10 Apr 2016 08:08 by SWest.
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
10 Apr 2016 13:12
#720206
The valve that is in it is brand new. He just cut the seat too deep I think.
  • zed1015
  • zed1015's Avatar
10 Apr 2016 15:23
#720217
Your next option is to try an oversize stainless valve which should fix the problem and you should really do the other three to match.
Obviously the seat will need cutting wider starting with the 45 first and then check the installed stem height of the new valve as you go.
Aim for the minimum height (which is in the manual ) so you have plenty of shim range.
Once that is ok cut the 30 and 60 to get the correct seat width.
If the machine shop cut the seat too deep they probably don't know what they are doing (or didn't care) and you should find someone else.
Any shop you take it to should check the existing installed height first and this would tell them how much room there is to play with before cutting the seats or tipping the valve.
Knowing the installed height tells you roughly what size shim will fit and how much to tip the valve before any work proceeds.
It sounds like this wasn't done.
The following user(s) said Thank You: PLUMMEN
  • bromz
  • 1981 kz1000 csr
11 Apr 2016 05:15
#720277
Ok guys I'm gonna call ape and talk to them. Please explain to me how an oversized valve might work or even a j valve??
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Apr 2016 05:25
#720281
The valve is wider so it will contact a undamaged area of the seat. I didn't know J valves were shorter. Good to know. If money is tight, one valve could be done. See what they say.
  • zed1015
  • zed1015's Avatar
11 Apr 2016 07:36
#720310
bromz wrote: Ok guys I'm gonna call ape and talk to them. Please explain to me how an oversized valve might work or even a j valve??
The explanation to the oversize valve solution is in my reply 2 posts back.
As for the 'J' valve length. That only applies to the older kickstart motors and I notice that you are working on the later one so it doesn't apply in this case.
I would contact Larry Cavanaugh or Joe Hooper (Pitstop performance) to do the work.
  • PLUMMEN
  • PLUMMEN's Avatar
11 Apr 2016 07:52
#720313
Check out larry cav ,He can probably fix it as good if not better than APE.
Probably a little cheaper also. ;)
  • bromz
  • 1981 kz1000 csr
11 Apr 2016 08:29 - 11 Apr 2016 08:33
#720325
Try a +1 so 33mm or 32mm
valve?
Last edit: 11 Apr 2016 08:33 by bromz.
  • pete greek1
  • pete greek1's Avatar
11 Apr 2016 08:57
#720331
bromz wrote: Try a +1 so 33mm or 32mm
valve?
If you send the head to Larry, it'll take all the guess work out, since he specializes in head work, & there may be other options
Pete
  • bromz
  • 1981 kz1000 csr
11 Apr 2016 09:32
#720341
I dont have 3 to 4 hundred to put into this head. I will push it to the curb with a free sign before i do that
  • zed1015
  • zed1015's Avatar
11 Apr 2016 09:58
#720362
valve?
You need a 33mm valve.
32mm is standard on the exhaust of the CSR.
