Valve guide size
- bromz
- 1981 kz1000 csr
Re: Valve guide size
08 Apr 2016 16:26
jetsRus has shims. I have a 205 on hand but I'll be needing it soon.
08 Apr 2016 16:29bromz wrote: Not sure I want to say. Hahahaha I went a little past.
The max is .012" I hope you didn't go past that. The bucket can dislodge the keepers and a dropped valve can be the result. :dry:
- bromz
- 1981 kz1000 csr
08 Apr 2016 16:38
Thanks, I've got a local shop about 25 miles away that has shim I can trade for. He has 200 and up. I just have a bad feeling that I get the 200 and still no clearance.
08 Apr 2016 16:45
That's quite a drop. Unless the guy was heavy handed, you shouldn't have any trouble.
- bromz
- 1981 kz1000 csr
08 Apr 2016 17:03
If the seat is toast, a new one can be installed. I hope not but it can be done.
- bromz
- 1981 kz1000 csr
09 Apr 2016 09:11
Got a 200 205 220 and 225 today. I will check after work.
- bromz
- 1981 kz1000 csr
09 Apr 2016 17:34
Well guys a 200 shim a valve stem ground and still no clearance!! Any last ditch ideas before I take it in to the machine shop??
09 Apr 2016 19:10
Wow, I hope you don't take it to the same place. A oversize valve might get you some more. Call APE.
kzzone.com/cams.html
- PLUMMEN
10 Apr 2016 01:54
Are you pointing the pointed end of lobe 180 degrees away from the shim when youre checking the clearance?
- bromz
- 1981 kz1000 csr
