Valve guide size
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
Re: Valve guide size
01 Apr 2016 06:52 - 01 Apr 2016 06:53
#718659
We did put the guide in the freezer and hit the hole with a bottle torch. also put permatex sleeve retainer on the guide then he tapped it in. I went out to the garage this morning just to see how i thought it did and man it seems tight. i pushed as hard as I could with my fingers and it didnt budge.
Last edit: 01 Apr 2016 06:53 by bromz.
The following user(s) said Thank You: KZB2 650
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Apr 2016 06:57
#718660
It should work. The seat should be ground to be sure the seat is centered. I dropped a valve in my Honda so that had to be done too. It was in 73 and lots of parts were available. I was making $3.25/hr at the time so it might as well have been $500. That hurt. I learned about valve adjustment the hard way. :dry:
The following user(s) said Thank You: PLUMMEN
  • bromz
  • 1981 kz1000 csr
01 Apr 2016 07:00 - 01 Apr 2016 07:02
#718661
I think thats why he said lap the valve and if anything looks funny bring it back and he would grind it
Last edit: 01 Apr 2016 07:02 by bromz.
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Apr 2016 07:21
#718665
Give it a shot and put up pics of the valve and seat.You can use a black marker on the seat and valve to show the mateing surface.
  • bromz
  • 1981 kz1000 csr
06 Apr 2016 04:48
#719495
Well i got the guide in nicely i thought?? When I put the valve in to lap it was perfectly clear the guide was crooked. So to the machine shop I went. The machinist re-cut the seat and ground the valve for me. Did a nice job! Now its time to go back together. The guy only charged me 10$ again. So sometimes its worth taking it to a professional. I will keep you guys posted on how the guide and that valve hold up.
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Apr 2016 04:52
#719496
Did he check the valve clearance and or tip the valve. Check it before putting it back together.
  • bromz
  • 1981 kz1000 csr
06 Apr 2016 12:12
#719576
Are you saying I should bolt the camshaft into the head and check clearance before installing the head???
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Apr 2016 12:15
#719578
Yes, you won't regret it.
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Apr 2016 12:21
#719579
Maybe I should explain further. Grinding the valve seats and valves make them sit deeper in the head. Too deep the valves have to be "tipped" to restore clearance. I put new valves in mine and wish I had checked. One valve is set at 210. That means I'll have to do it again soon. :(
  • bromz
  • 1981 kz1000 csr
06 Apr 2016 12:39 - 06 Apr 2016 12:40
#719583
That's what I thought you meant. Question. If I need to take a little off can I carefully file the end of the stem??cause this valve is in the head further than the others so I'm sure I will have to be in the low end of the shims
Last edit: 06 Apr 2016 12:40 by bromz.
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Apr 2016 13:11
#719589
Best to take it out and have it done. I thought about doing it myself while still together but I'd have to have a way to grind them square.
  • bromz
  • 1981 kz1000 csr
06 Apr 2016 13:26
#719591
I wouldn't file it without removing it that's for sure.
