Valve guide size
  • zed1015
  • zed1015's Avatar
Re: Valve guide size
06 Apr 2016 13:42
#719592
You cannot file the valve stem tip.
It needs to be ground perfectly square using the correct valve stem grinding machine fixture or a lathe.
The following user(s) said Thank You: PLUMMEN
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
06 Apr 2016 14:02
#719595
10-4 if it needs ground I will take it back to the machine shop!
  • zed1015
  • zed1015's Avatar
06 Apr 2016 14:21
#719598
You will also need to take the head at the same time and provide the machinist with the minimum and maximum stem height service limits and the minimum distance from the stem tip to the collet groove ( all found in the factory service manual).
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • bromz
  • 1981 kz1000 csr
06 Apr 2016 16:34
#719614
I bolted the camshaft in the best I could for taking a valve measurement and I had no clearance. There was a 245 in there and smallest I had is a 230 so I put that in and still no clearance so off to the shop to get some smaller sizes
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Apr 2016 20:01
#719649
You might get a 200 while you're at it If you're lucky you'll be in the 210-220 range. My intake are in the 230 range but the exhaust are in the 210-220. I wish I had checked.
  • bromz
  • 1981 kz1000 csr
07 Apr 2016 10:37 - 07 Apr 2016 13:51
#719734
Does anyone have a 2.00 shim to lend for measuring purposes?? Never mind I'm gonna take my head in and have him cut the stem to fit within specs so I don't have to use a 2
Last edit: 07 Apr 2016 13:51 by bromz.
  • bromz
  • 1981 kz1000 csr
08 Apr 2016 13:42
#719892
Well got the stem cut down several thousands . I will see tonight what I gained!
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Apr 2016 13:47
#719894
Did you go the limit?
  • bromz
  • 1981 kz1000 csr
08 Apr 2016 13:50 - 08 Apr 2016 13:51
#719895
Not sure I want to say. Hahahaha I went a little past.
Last edit: 08 Apr 2016 13:51 by bromz.
  • bromz
  • 1981 kz1000 csr
08 Apr 2016 15:26
#719911
Well still no clearance with the stem cut and a 230 shim. Got to go to a smaller shim now
  • SWest
  • SWest's Avatar
  • 10 22 2014
