Valve guide size
- bromz
- 1981 kz1000 csr
Valve guide size
30 Mar 2016 17:05
I removed my worn valve guide and bought a standard to replace it. Slides right in! So I ordered a .002 and .004 oversized same thing. Where do I go from here?
Re: Valve guide size
30 Mar 2016 17:33
Did metal come out with it?
www.kzzone.com/valves.html
They have a larger size.
In the day I had a friend knerl a valve guide on his lathe. Metal came out with the old one. It worked well.
- bromz
- 1981 kz1000 csr
30 Mar 2016 17:55
I have access to a machine shop if they are willing to do it. worked ok? metal had to of come out cause I couldn't get all the carbon off.
- PLUMMEN
30 Mar 2016 17:57
Thats why you should glass bead the combustion chambers/ports to get all of the carbon out of there first.
- bromz
- 1981 kz1000 csr
30 Mar 2016 17:58
also the one I see on kzzone.com is .004 that's the biggest I see
- PLUMMEN
30 Mar 2016 17:59Knurling the inside of guides to take the slop out used to be a common thing,Ive never seen it done on the outside :laugh:swest wrote: Did metal come out with it?
30 Mar 2016 18:05
It worked like a charm. Barry of Handy Cycles was old school. I learned a lot from him.
The following user(s) said Thank You: PLUMMEN
30 Mar 2016 18:32
Look further down the page at APE. They sell some bronze guides they label as "repair" guides that are .502". I presume you use a .500 reamer for those. Call APE and ask.
30 Mar 2016 18:37
Yup, that's why I posted the link. It will have to be professionally done anyway.
- bromz
- 1981 kz1000 csr
30 Mar 2016 18:45
how much bigger is a .502 than original? why cant I just put oversized guide in and lap the vavle?
30 Mar 2016 18:55
Call them and ask. I wouldn't be comfortable doing that myself.
- bromz
- 1981 kz1000 csr
30 Mar 2016 19:11
I will see tomorrow if the machinist can knurl the outside of it and see if that gets me there. If not its off to the professionals.
