Mikuni VM 33 Carbs
- KZB2 650
Re: Mikuni VM 33 Carbs
15 Nov 2016 08:58
I agree on tightening them by hand.... I recently tightened my plugs (for the first time) to the min using 2 diff wrenches and they felt too tight for me (damn near a full 1/3rd).... same with the filter bolt, drain plug and valve cover bolts. Pan, oil pump, cam gears, cam cap bolts, starter clutch bolts etc I carefully went with the min on the wrench (sneaking up on them with a 3 inch wrench then the torgue wrench) but will go back to a good feel on most. Do you use a small amount of anti seize on the plugs.... some don't but I pull mine quite a bit too and I think its really protecting the threads from wear.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
15 Nov 2016 10:35
I don't use anti seize on anything except my old Ford truck heads or things like that. I use a stubby ratchet or box end wrench. I've broken and stripped plenty of bolts in my time and have developed a feel for them. Others may prefer to use a torque wrench and I do use one for head bolts and such.
- daveo
15 Nov 2016 12:10
Well, that explains why my spark-plug crush washers are flattened out after one or two removals. I thought the FSM torque spec of 20 ft. lbs. was to be taken as gospel, but such is the result of my experience. :pinch:
Back to my jet question... :S
My RS36 carburetors are setup with 17.5 pilot fuel jets and 0.7 air jets.
Does that have exactly the same effect as using 20 pilot fuel jets and 0.8 air jets?
1982 KZ1100-A2 Sleeper 😎
15 Nov 2016 13:11
I would suspect the air jets are for the mains not the pilots. Pic?
- daveo
15 Nov 2016 21:12swest wrote: I would suspect the air jets are for the mains not the pilots. Pic?
Steve, hope this helps.
Pic: Note Pilot Air Jet is the small one on the right.
15 Nov 2016 21:24
Main air jet plugged? Is that a accelerator pump nozzle? Have you tried looking on the jetsrus charts like they have for the Micunis? Maybe try Sudco for the jetting for your machine. Also the float level looks a little high. That would make it rich on the bottom.
- daveo
15 Nov 2016 22:07swest wrote: Main air jet plugged? Is that a accelerator pump nozzle? Have you tried looking on the jetsrus charts like they have for the Micunis? Maybe try Sudco for the jetting for your machine. Also the float level looks a little high. That would make it rich on the bottom.
Main air jets plugged, yes as exploded part list states and what looks like a jet is actually a plug.
Yes, the accelerator (pump) nozzle is shown vertical in the bore in front of the throttle slide, directly below the blue P.
All good on the instructions for jetting, except for the Mikuni application chart indicates Pilot screw setting range from 1/4 - 1/2 turn (off lightly seated I believe), not 2 1/2 - 3 turns. Runs well at 1/4 turn out currently.
Float levels measured and set correctly at 17 mm per Mikuni instruction manual. There is no measurement information on which to base using the clear-tube float setting method that works on the BS34's so well.
- JOE MKII
16 Nov 2016 03:34
I agree with Swest , that fuel level looks high, even if the floats are correct lowering the fuel level a mm or less at a time is worth a try if your having problems.
Float level is a viable and accepted way to fine tune a carb , within reason of course.
I believe its called "Oppositional Defiance Disorder"
- daveo
16 Nov 2016 08:27JOE MKII wrote: I agree with Swest , that fuel level looks high, even if the floats are correct lowering the fuel level a mm or less at a time is worth a try if your having problems.
Not sure how to adjust the floats to lower the fuel levels, other than excessively tweaking the float tab, and then whether it would make much difference or not.
When I first got the carbs, I set the floats to 19 mm, concerned that fuel would drain when the bike was left to rest on the side-stand (when these pics were taken).
Subsequently I reset them to the Mikuni spec, and they don't leak at 17 mm either. :S
BTW, after checking the fuel levels with the special clear tube (pic 1), I found that neither setting affected the fuel height more than 1 mm, so I reset them to 17 mm. It seems strange that the levels are above the bowl top, considering BS34's were easily set 3-4 mm below that.
Pic 2 shows 7 mm measured from the top of the bowl to the fuel drain-tube hole, 2-3 mm above the fuel per pic 3.
16 Nov 2016 10:53 - 16 Nov 2016 10:54
I'd set them even with the bottom of the bowl flange and see how it runs. I don't care for it being past the gasket. Might be too rich that way and could leak.
Last edit: 16 Nov 2016 10:54 by SWest.
- daveo
16 Nov 2016 12:24
No leaks yet, but your viewpoint makes sense. Not sure how to get the float tabs bent enough to drop the level 4 mm though.
Are you confident its not supposed to be this way? Take a look at this pic, and consider if the pump plunger needs to be immersed with fuel to work properly.
Thanks again.
Thanks again.
16 Nov 2016 12:57
Is there a port on the bottom?
