- Thank you received: 33
Bike keeps dying, high idle, help?83 kz650
- nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
- H1Vindicator
- Thank you received: 53
That is incorrect.nickleo373 wrote: Yes your fuel should rise to about 1-3mms below the float bowl gasket
The fuel level is measured in relation to the bottom edge of the carburetor body.
The factory manual shows a drawing & it should be 3.0mm +/- 1.0mm below the carb body.
- Thank you received: 2098
H1Vindicator wrote:
That is incorrect... The fuel level is measured in relation to the bottom edge of the carburetor body.nickleo373 wrote: Yes your fuel should rise to about 1-3mms below the float bowl gasket
- H1Vindicator
- nickleo373
1981 KZ550C LTD
- Thank you received: 1656
- Tj_saxon
Wasting money I don't have, on parts I don't need, to impress people I don't know.
83 KZ650CSR
- Tj_saxon
Attachment image_2013-09-01.jpg not found
Also, why in the world can I feel the electricity going through my plug wires. I put my finger on each one to push them down on the the plugs well and I could feel the pulse in each one. Normal? Lol.
83 KZ650CSR
- rcook52459
- Thank you received: 8
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
- Tj_saxon
83 KZ650CSR
- rcook52459
- Tj_saxon
Also looking at where my plug wires connect just before the plug I found this on number 3.
Attachment image_2013-09-01-2.jpg not found
I could be wrong. But that looks broke lol.
83 KZ650CSR
