- Thank you received: 512
Bike keeps dying, high idle, help?83 kz650
- baldy110
25 Aug 2013 18:05 #603025
by baldy110
Replied by baldy110 on topic Bike keeps dying, high idle, help?83 kz650
Sounds like someone installed Torx screws, I HATE those things.
- Tj_saxon
25 Aug 2013 18:12 #603027
by Tj_saxon
Wasting money I don't have, on parts I don't need, to impress people I don't know.
83 KZ650CSR
Replied by Tj_saxon on topic Bike keeps dying, high idle, help?83 kz650
Are they bad? I've never worked with these before. They look easy to round out...
83 KZ650CSR
- Luckie1
- the road to hell is paved with good intentions....
25 Aug 2013 18:15 #603029
by Luckie1
Replied by Luckie1 on topic Bike keeps dying, high idle, help?83 kz650
how do you sync the carbs?
- Tj_saxon
25 Aug 2013 18:19 #603031
by Tj_saxon
83 KZ650CSR
Idk how. So as of now I don't lol.
83 KZ650CSR
- Tj_saxon
26 Aug 2013 18:20 #603191
by Tj_saxon
83 KZ650CSR
Woohoo!!!!
83 KZ650CSR
- Thank you received: 1656
26 Aug 2013 19:55 - 26 Aug 2013 19:56 #603209
by martin_csr
Replied by martin_csr on topic Bike keeps dying, high idle, help?83 kz650
Before trying to remove the old carb holders, this is one of those cases in which I'd probably try to get my hands on some Kroil penetrant - apply the stuff & give it time to work. At the least I would use LiquidWrench penetrating spray lubricant & give it time to work, letting it sit overnight or longer.
Also, get a quality torx bit (or whatever type of driver is appropriate). Cheapy torx bits fail miserably - don't ask how I know. doh.
The good news is that maybe the carb holder screws haven't been in there that long, so with any luck they'll all come out w no real problems... fingers crossed.
Last edit: 26 Aug 2013 19:56 by martin_csr.
The following user(s) said Thank You: Tj_saxon
- Tj_saxon
26 Aug 2013 20:01 #603211
by Tj_saxon
83 KZ650CSR
Daddy's big girl helping out
83 KZ650CSR
- Tj_saxon
26 Aug 2013 20:13 #603214
by Tj_saxon
83 KZ650CSR
Daddy's big girl helping out round 2
83 KZ650CSR
- Tj_saxon
27 Aug 2013 06:30 #603294
by Tj_saxon
83 KZ650CSR
Thanks for the heads up, oddly they were super easy to get off. 3 weren't even torqued down. Just finger tight. I got everything on and letting the internals to the carbs soak over night. Will give an update tomorrow.
83 KZ650CSR
- Tj_saxon
27 Aug 2013 19:30 #603383
by Tj_saxon
83 KZ650CSR
Ok guys. Got the bike fired up today. With choke all the way out it idles at 4000rpms on the second setting it is finally staying on and idling at 1200rpms and on the last notch it dies still... No more vacuum leaks. It's running a lot better. I think I found how to sync the carbs (if any one could give a yes or no that would be great) I added a photo of it. It is really small long needles that feel spring loaded. If its not how I sync my carbs can someone just tell me what they are? Also upon inspecting my big jet (the small gold screw with a hole in ít that is the bowl) I read 107.5..my friend said that this is high. Any ideas? If anyone has any suggestions as always they will be greatly appreciated.
83 KZ650CSR
- nickleo373
- Thank you received: 33
27 Aug 2013 20:03 #603392
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
Replied by nickleo373 on topic Bike keeps dying, high idle, help?83 kz650
I'm not sure of the correct size of the main jet for the 650 however it's likely if the main was replaced, the pilot was changed too. The pilot jets control your bikes idle and low rpms and could be causing the problem
1981 KZ550C LTD
- nickleo373
27 Aug 2013 20:15 #603395
by nickleo373
1981 KZ550C LTD
Main Jet Size: 102.5
Pilot Jet Size: 15
According to the internet this is what your jets are supposed to be
Pilot Jet Size: 15
1981 KZ550C LTD
