- Thank you received: 1656
Bike keeps dying, high idle, help?83 kz650
05 Sep 2013 19:26 - 05 Sep 2013 19:31 #605091
by martin_csr
Replied by martin_csr on topic Bike keeps dying, high idle, help?83 kz650
The cylinders, carbs, etc are numbered 1-2-3-4 ... left-to-right ... sitting on the bike.
1-4 spark plug wires -->> right side coil -->> red/black igniter leads
2-3 spark plug wires -->> left side coil -->> red/green igniter leads.
My coils have + & - embossed on them, as illustrated in the manual. It says to connect the red igniter leads to + and the green & black leads to - .
Last edit: 05 Sep 2013 19:31 by martin_csr.
- Tj_saxon
07 Sep 2013 16:29 #605393
by Tj_saxon
Wasting money I don't have, on parts I don't need, to impress people I don't know.
83 KZ650CSR
Replied by Tj_saxon on topic Bike keeps dying, high idle, help?83 kz650
This is weird but I am pretty sure when I swap my right hand side plugs (1&4) my bike runs the exact same. I will take a video later as evidence lol. Any who I got the stuff to sync my carbs and check fuel level in the bowls. As far as syncing the carbs go do I screw the screws down then back them out 2 turns then just sync them up?
83 KZ650CSR
- Thank you received: 2098
07 Sep 2013 23:00 #605449
by Patton
Replied by Patton on topic Bike keeps dying, high idle, help?83 kz650
- Tj_saxon
10 Sep 2013 22:32 #605924
by Tj_saxon
83 KZ650CSR
Ok, do I got plugs and everything right. Is thee a good how to on how to adjust valves. I think one of my valves is loose because I hear a ticking sound and someone told me it just needed to be adjusted.
83 KZ650CSR
- Thank you received: 2829
10 Sep 2013 22:34 #605925
by 650ed
Replied by 650ed on topic Bike keeps dying, high idle, help?83 kz650
There is a great "how to" on adjusting valves in the Kawasaki Service Manual. It goes into great detail and gives photos that help make everything clear. Ed
11 Sep 2013 10:11 - 11 Sep 2013 10:19 #605989
by martin_csr
Also, make sure the spark plugs are correct & gapped.
NGK B7ES or ND W22ES-U ... gap = ~0.7 - 0.8 mm ... tightening torque = 20 ft/lbs
Patton's image edited.
Double-check the connections.Tj_saxon wrote: Ok, do I got plugs and everything right. Is thee a good how to on how to adjust valves. I think one of my valves is loose because I hear a ticking sound and someone told me it just needed to be adjusted.
Last edit: 11 Sep 2013 10:19 by martin_csr.
