Bike keeps dying, high idle, help?83 kz650
- Tj_saxon
20 Aug 2013 18:03 - 20 Aug 2013 18:33 #602347
by Tj_saxon
Wasting money I don't have, on parts I don't need, to impress people I don't know.
83 KZ650CSR
Replied by Tj_saxon on topic Bike keeps dying, high idle, help?83 kz650
This is what I'm getting.
I tried posted a video but I don't think it worked. Ed the fuel was turned to on. I got it to start by playing with the idle screw. But now if I give it any throttle it dies. Same with pushing the choke in.
83 KZ650CSR
Last edit: 20 Aug 2013 18:33 by Tj_saxon.
- Tj_saxon
20 Aug 2013 18:53 #602355
by Tj_saxon
83 KZ650CSR
BUT! On a happy note it is no longer dumping fuel everywhere. Thanks again guys for all the help on that. Hopefully someone can help me figure this out and I can have the bike on the road in no time.
83 KZ650CSR
- nickleo373
- Thank you received: 33
20 Aug 2013 20:21 #602363
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
Replied by nickleo373 on topic Bike keeps dying, high idle, help?83 kz650
Try checking for vacuum leaks in your carb boots. If it will idle spray carb spray at the boots and listen for a change in idle. If you hear a change you have a vacuum leak
1981 KZ550C LTD
- Tj_saxon
20 Aug 2013 20:32 #602365
by Tj_saxon
83 KZ650CSR
Will do, thanks for the tip.
83 KZ650CSR
- Tj_saxon
20 Aug 2013 21:58 #602373
by Tj_saxon
83 KZ650CSR
A little off subject but what is the bike supposed to idle at with choke on and idle with choke off and warm? Sorry I just think when I was messing with the idle screw I might have messed it up and that may be why it's running bad. Or would that even make sense.
83 KZ650CSR
- Thank you received: 2829
20 Aug 2013 22:18 #602376
by 650ed
Replied by 650ed on topic Bike keeps dying, high idle, help?83 kz650
When warmed up and with the choke off it should idle between 950 - 1050 rpm. Ed
- Tj_saxon
20 Aug 2013 22:27 #602377
by Tj_saxon
83 KZ650CSR
Ok thank you. I'm gonna play with the idle screw and check for vacuum leaks when I get home.
83 KZ650CSR
- Tj_saxon
21 Aug 2013 01:31 #602408
by Tj_saxon
83 KZ650CSR
Ok guys, after struggling to get the bike started (I found it best to let it prime for a second then turn it on) idle was bouncing between like 4000 and 5000 rpms as I played with the idle control. Still couldn't make it run without the choke. Spraying carb spray on the little rubber things on the motor I found that all but one I believe increased idle greatly. Do they make replacement ones or is there something I should do?
83 KZ650CSR
- nickleo373
21 Aug 2013 01:51 - 21 Aug 2013 02:00 #602409
by nickleo373
1981 KZ550C LTD
Z1 enterprises will probably have replacements. Fixing the vacuum leaks should keep the rpms lower and allow it to come off choke. When removing the old holders make sure to soak them in kroil or some sort of penetrating oil for a couple days prior to attempting torremove them. Also make sure you aren't trying to remove the screws with phillips head screwdrivers. They are JIS screws and a Phillips screwdriver will strip them. 650ed has a page that can show you how to make them for free if you don't own any JIS screwdrivers.
1981 KZ550C LTD
Last edit: 21 Aug 2013 02:00 by nickleo373. Reason: update
The following user(s) said Thank You: Tj_saxon
- nickleo373
21 Aug 2013 01:56 #602410
by nickleo373
1981 KZ550C LTD
1981 KZ550C LTD
- Tj_saxon
21 Aug 2013 02:41 #602414
by Tj_saxon
83 KZ650CSR
Ill have to look into that and yes those are them. I found them on another site called partsnmore for 47 dollars.any one ever done business with them?
83 KZ650CSR
- Tj_saxon
21 Aug 2013 02:47 #602416
by Tj_saxon
83 KZ650CSR
Oh also, looked under my seat and found this lol.
83 KZ650CSR
