Bike keeps dying, high idle, help?83 kz650
- Tj_saxon
02 Sep 2013 02:07 - 02 Sep 2013 02:13 #604389
by Tj_saxon
Wasting money I don't have, on parts I don't need, to impress people I don't know.
83 KZ650CSR
Replied by Tj_saxon on topic Bike keeps dying, high idle, help?83 kz650
Ignore, not sure how my phone posted the same thing 5 times. Sorry guys
83 KZ650CSR
Last edit: 02 Sep 2013 02:13 by Tj_saxon.
- Tj_saxon
02 Sep 2013 02:08 #604390
by Tj_saxon
83 KZ650CSR
Ok, so I hear there is a way to judge how my bike is running jus from looking at the plugs. Would any one care to describe this process.
Attachment image_2013-09-02-2.jpg not found
83 KZ650CSR
- rcook52459
- Thank you received: 8
02 Sep 2013 08:40 #604421
by rcook52459
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
Replied by rcook52459 on topic Bike keeps dying, high idle, help?83 kz650
3 of them look alittle lean and that 4th one is that the plug where the bad wire was.it not firing or bad compression.take a compression check if u can.see what the readings are.plus google how to read spark plugs.lots of info,even youtube video's.if that 4th one was the one with the bad wire change the wire and see how it runs.only running on 3 cylinders is what it looks like.
- Tj_saxon
02 Sep 2013 17:58 #604510
by Tj_saxon
83 KZ650CSR
Ok thanks a lot. I know you guys are tired of hearing/seeing it but thanks again so much everyone for the help. Btw to Martin I took that little cap on the right hand side and inside was spotless so I didn't touch it. I have pictures if you would like to see.
83 KZ650CSR
- Tj_saxon
02 Sep 2013 18:47 #604517
by Tj_saxon
83 KZ650CSR
On a side note I went and looked at cylinder 4s plug wire and found this.
Attachment image_2013-09-02.jpg not found
83 KZ650CSR
- rcook52459
02 Sep 2013 18:53 #604518
by rcook52459
clean or replace plug get a new wire.see how much better it will run
- Tj_saxon
04 Sep 2013 17:59 #604829
by Tj_saxon
83 KZ650CSR
Hi, new question. If I buy just normal spark plug wires do I need to buy the little NGK plug caps with resistors built in them or buy new plugs that the r in the name (b7res I believe)?
83 KZ650CSR
- Thank you received: 1656
04 Sep 2013 21:21 - 04 Sep 2013 21:22 #604855
by martin_csr
Replied by martin_csr on topic Bike keeps dying, high idle, help?83 kz650
With a mechanical advancer, I don't think you have to worry about the resistor stuff. I don't know what type of spark plug wires & caps the 650-CSR came with originally. For the correct spark plugs you can use either NGK B7ES or ND W22ES-U.
I installed a Dyna spark plug wire set (DW200 - 7mm copper core) & the green Dyna 3.0 ohm coils from Z1Enterprises.com, and I use the NGK spark plugs.
Last edit: 04 Sep 2013 21:22 by martin_csr.
- Tj_saxon
05 Sep 2013 01:54 #604949
by Tj_saxon
83 KZ650CSR
What exactly does it do and if I don't use one what harm would it do? I've always wondered about resistors and what not.
83 KZ650CSR
05 Sep 2013 12:02 - 05 Sep 2013 17:33 #605001
by martin_csr
I don't think there will be any harm to the bike. The ignition system can cause interference to other stuff not related to the motorcycle - electronic devices, such as radios & maybe walkie-talkies. Later models have electronic timing advance - I think the 84 KZ700 is in that category since it has a non-mechanical pulsing coil rotor, but I have no idea if those bikes need suppression core spark plug wires or resistor caps - I'd guess there could be interference w the ignition, but I really don't know. At any rate I wouldn't worry about it.
Last edit: 05 Sep 2013 17:33 by martin_csr.
- Tj_saxon
05 Sep 2013 17:09 #605058
by Tj_saxon
83 KZ650CSR
Ok cool, I can order spark plug wires with peace of mind now lol.
83 KZ650CSR
- Tj_saxon
05 Sep 2013 19:06 - 05 Sep 2013 19:09 #605090
by Tj_saxon
83 KZ650CSR
Ok guys I ghetto rigged some 76 celica spark plug wires on there for now. Still seems to be running the same. When I rev it idle will catch. If I play with the idle screw it will come down. I have to have idle so low the bike seems like its about to die for it not to catch. All that I see left to do is sync the carbs and check the gas level in each carb. My tube should be here soon for that.
Also correct me if I am wrong but from the back tire facing the front of the bike the wires go in this order
2. 4
3. 1
2. 4
3. 1
83 KZ650CSR
Last edit: 05 Sep 2013 19:09 by Tj_saxon.
