Bike keeps dying, high idle, help?83 kz650
- Tj_saxon
18 Aug 2013 16:57 #602028
by Tj_saxon
Wasting money I don't have, on parts I don't need, to impress people I don't know.
83 KZ650CSR
Bike keeps dying, high idle, help?83 kz650 was created by Tj_saxon
Hi all, new to bikes, kinda new to carbs, I recently got an 83 kz650csr and it won't start with out choke pulled to start off. Second after starting and giving around 5 minutes to heat up and pushing choke in the bike dies. Instantly. Also there are two clear tubes leaking gas out? Overflows? Also when you start the bike it idles up to 6k rpms and kinda struggles o stay there ( erratic idle I suppose you would call it). If helpful I can take a video of it an post it as I really don't know the best ways to describe this stuff. Any words of wisdom would be greatly appreciated. Also if a search would have helped me I tried to do that and it won't bring anything up on my phone it just freezes when I click search. Thanks in advance.
83 KZ650CSR
- nickleo373
- Thank you received: 33
18 Aug 2013 17:02 #602029
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
Replied by nickleo373 on topic Bike keeps dying, high idle, help?83 kz650
Sounds like you might have a couple carb issues. I'd start by pulling the carbs off the bike and do a full cleaning with carb spray, a wire brush, and compressed air. When you take off the float bowls make sure your floats are able to move freely and make sure your fuel valves above the floats don't have any debris inside of them. After that take your pilot jets and main jets out of the carbs and soak them overnight in carb clean. Blow compressed air through the jets the next day. Sync the carbs and reinstall them to the bike
1981 KZ550C LTD
- Thank you received: 2829
18 Aug 2013 17:05 #602031
by 650ed
Replied by 650ed on topic Bike keeps dying, high idle, help?83 kz650
Welcome aboard! Pictures would definitely help; especially the clear tubes with fuel leaking out. Ed
- Tj_saxon
18 Aug 2013 17:51 #602035
by Tj_saxon
83 KZ650CSR
Replied by Tj_saxon on topic Bike keeps dying, high idle, help?83 kz650
Ok, I will try and find a guide on how to take them out and take them apart and try that. Thanks for the fast responses. Ed I will deff take some pictures tonight when I get home from work. Maybe even a video of I have time. Thank you fe the welcome and the fast response.
83 KZ650CSR
- baldy110
- Thank you received: 512
18 Aug 2013 19:11 #602043
by baldy110
Replied by baldy110 on topic Bike keeps dying, high idle, help?83 kz650
Classic symptoms of dirty carbs. Has the bike been sitting for a period of time with gas left in them?
- Tj_saxon
18 Aug 2013 19:33 - 18 Aug 2013 20:04 #602045
by Tj_saxon
83 KZ650CSR
Most likely, it had spider webs on it.
83 KZ650CSR
Last edit: 18 Aug 2013 20:04 by Tj_saxon. Reason: On*
- nickleo373
18 Aug 2013 21:36 #602058
by nickleo373
1981 KZ550C LTD
If you have youtube go on there and look up mrmaxstorey. He has a lot of step by step videos of how to clean carbs the right way. It helped me a lot when I was learning.
1981 KZ550C LTD
- Tj_saxon
18 Aug 2013 21:42 #602060
by Tj_saxon
83 KZ650CSR
Thank you, that should be very helpful as I have never really cleaned one.
83 KZ650CSR
- Tj_saxon
19 Aug 2013 04:29 #602092
by Tj_saxon
83 KZ650CSR
Ok these are the clear tubes. I believe the bike is constantly leaking gas out of these tubes as the ground was soaked in gas. Also the air box had gas in it. Any ideas on that guys?
83 KZ650CSR
- Tj_saxon
19 Aug 2013 04:38 #602093
by Tj_saxon
83 KZ650CSR
Also this black tube, why is that one the only one with a tube? I honestly don't even remember what it connects to. And the far left and right one had tubes if I recall correctly that ran up to a t and went somewhere. So why is that one capped off?
83 KZ650CSR
- nickleo373
19 Aug 2013 05:04 #602094
by nickleo373
1981 KZ550C LTD
Not sure about the hoses but if your airbox has gas in it you may also have gas in your crankcase. To check you can sniff inside where you add oil. If it smells like gasoline it is most likely a carburetor problem. If it is a carb problem it will probably be solved my cleaning the carbs and setting the floats to the correct height
1981 KZ550C LTD
- Tj_saxon
19 Aug 2013 06:09 #602095
by Tj_saxon
83 KZ650CSR
You tube time for setting the floats, I'm halfway through cleaning the carb and haven't done that...
83 KZ650CSR
