rs34's
- Z1109R Fin
Re: rs34's
24 Jun 2009 07:22 - 24 Jun 2009 07:23
timebomb33 wrote:
I think those are HSR´s not RS that are used on HD´s. Roller-bearings are also in Mikunis TMR -line-up. These are the evolutuion of TM and RS I think.(Sorry about links in German)Maybe you´l find same in on Sudco etc. pages.
www.mikuni-topham.de/DEUTSCHSITE/Deutsch/FRAMEDEUTSCH.html
These are my wet dream. Mikuni TMR36:
about the only flatslides that dont rattle alot are the ones everybody is putting on there harleys the 42,45 mm mikuni flatslides are supported by roller bearings up and down bothsides so it keeps them quiet.
Z1000R ´83...Slightly modified...
Last edit: 24 Jun 2009 07:23 by Z1109R Fin.
- 79MKII
- Love Them Kaws!
Re: rs34's
26 Jun 2009 19:01
I tried the bike without the baffle and it seemed to run even better - with less clacking! I don't know if they really rattled less or if I just couldn't hear it!
Anyway, I'd love to ride without the baffle but we get tickets around here for such crimes against society.
Now that the carbs are dialed in, I think I'll try another exhaust. I have a nice big Yoshi pipe I've been dying to try out - nearly 3" of pipe all the way back! That V&H street system I have really seems to be choking the 1260 motor.
The Kaw List:
- davel
Re: rs34's
26 Jun 2009 19:37
79MKII wrote:
In my experience, the V&H pipe will work well with a competition baffle. Stock baffle chokes the exhaust and no baffle seriously hurts low end and mid range and ears. Competition baffle is the answer.
Re: rs34's
26 Jun 2009 20:26
Z1109R Fin wrote:
Beautiful carbs.
But appear more of a down-draft design, and am dubious as to whether feasible on KZ's where carbs are fitted in level position.
Good Luck!
...Mikuni TMR36....
Beautiful carbs.
Good Luck!
- mark1122
- Keep twisting it
Re: rs34's
27 Jun 2009 06:21 - 27 Jun 2009 06:34
i have no rattle or clack in my RS34's. i have a 2 1/16" I.D. baffle.
sometimes u may hear the odd clack at idle.
The Keihins flat slides do have rollers on the slides.
I do have an annoying creek somewhere though.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 27 Jun 2009 06:34 by mark1122.
- 79MKII
- Love Them Kaws!
Re: rs34's
27 Jun 2009 08:38 - 27 Jun 2009 08:57
davel wrote:
I do have the comp baffle in there already. It's better but not great. I even drilled it to open it up a bit more. It just seems that the end of the collector is so small even compared to the kerkers. I was always a big fan of the V&H pipe because it has less bends, but the collector size has me wondering. It's the same pipe I had on the bike before but now it's bigger cc, head work, bigger carbs etc... and doesn't seem to work as well.
79MKII wrote:That V&H street system I have really seems to be choking the 1260 motor.
The Kaw List:
Last edit: 27 Jun 2009 08:57 by 79MKII.
- mark1122
- Keep twisting it
Re: rs34's
27 Jun 2009 09:07
What is the ID of your collector? my KERker is 2 5/16" id , 2.5 OD.
mine works better with a baffle than without in the low and mid range.
Morriwaki's pipe for the ZRX12 looks to have a 2.5" od collector.
www.moriwaki.co.jp/global/product/ex.php...SAKI&model=ZRX1200#1
i dont seem to see any pipes with big 3" collectors anymore.
This is the size prescibed by a header tuning artical for a 1327cc and 1075cc motor.
This book has tons of good information.
ISBN 0854292756
Performance Tuning in Theory & Practice by A. Graham Bell
--- Header Collector Specs (Conventional Straight Tube) ---
Diameter= 2.188 to 2.438 Tuned Lengths= 13.2 best and also 6.6 or 26.5
--- Header Collector Specs (Megaphone or Diffuser Cone Shape) ---
Diameter= 1.688 taper to 2.688 Megaphone/Diffuser Length= 13.2 inches
Best HP/TQ Tuned Collector Lengths= 13.2 , 26.5 , 53.0 , 105.9 inches long
Worst HP/TQ Loss Collector Lengths= 19.9 , 39.7 , 79.4 , 158.9 inches long
---- Collector's Harmonics (includes Intermediate, Muffler , TailPipe) ----
1st Harmonic = 105.9 inches long ... longest with Mufflers and TailPipes
2nd Harmonic = 53.0 inches long ... longest recommended with Mufflers
3rd Harmonic = 26.5 inches long ... more bottom-end Torque
4th Harmonic = 13.2 inches long ... highly recommended , best Torque Curve
5th Harmonic = 6.6 inches long ... reduced Torque , more top-end HP sometimes
6th Harmonic = 3.3 inches long ... reduced Torque , not recommended
Here's a 1075 motor, 8K Peak HP RPM with 2x
--- Single Primary Pipe Specs --- for 65.599 CID from 6000 to 8500 RPM
1075 cc Diameter= 1.014 to 1.139 (3/8â€= .375, 7/16â€=.4375â€) Length= 22.5 to 25.1 inches long
(1327cc Diameter= 1.153 to 1.278 Length= 22.3 to 24.9 inches long)
1075cc:
--- 2-Step Primary Pipe Specs ---
1st Dia. inches= 1.014 Length= 11.2 to 12.5
2nd Dia. inches= 1.139 Length= 11.2 to 12.5
--- 3-Step Primary Pipe Specs ---
1st Dia. inches= 1.014 Length= 7.5 to 8.4
2nd Dia. inches= 1.139 Length= 7.5 to 8.4
3rd Dia. inches= 1.264 Length= 7.5 to 8.4
Inside Diameter= 2.201 (Kerker = 2.3125â€) Tuned Lengths= 13.2 best and 6.6 or 26.4
Diameter= 1.701 taper to 2.201 Megaphone/Diffuser Length= 13.2 inches
-- Total Exhaust System Tuned Lengths (Primary ends to TailPipe end) --
Best HP/TQ Tuned Collector Lengths= 13.2 , 26.4 , 52.9 , 105.7 inches long
Worst HP/TQ Loss Collector Lengths= 19.8 , 39.6 , 79.3 , 158.6 inches long
Note=> measured from where the Primary Pipes end inside the Collector to the point the tailpipe exits into the atmosphere.
Note-> all Pipe Diameters are OD and based-off .0625 inch Pipe thickness
ISBN 0854292756
1075cc:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Re: rs34's
27 Jun 2009 10:24 - 27 Jun 2009 10:35
79MKII wrote:
Was thinking V&H offered two competition baffles in addition to the standard baffle, but below link indicates only the standard plus one competition.
V&H Baffles
Good Luck!
[Click on image to enhance view]
...I do have the comp baffle in there already. It's better but not great. I even drilled it to open it up a bit more....
V&H Baffles
Good Luck!
Last edit: 27 Jun 2009 10:35 by Patton.
- mark1122
- Keep twisting it
Re: rs34's
27 Jun 2009 12:08
79MKII wrote:
I do have the comp baffle in there already. It's better but not great. I even drilled it to open it up a bit more. It just seems that the end of the collector is so small even compared to the kerkers. [/quote]
what is the ID of a comp baffle?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
Re: rs34's
28 Jun 2009 08:04
Can only measure OD's right now, but here's what I have:
V&H = 2.1"
Kerker = 2.5"
Yoshi = 2.9"
The ID of the V&H comp baffle is 1.75"
V&H = 2.1"
Kerker = 2.5"
Yoshi = 2.9"
The Kaw List:
- mark1122
- Keep twisting it
Re: rs34's
28 Jun 2009 08:16
Well it's nice to have tose 3 pipes at your finger tips.
According to Bells math. the smaller pipe is best. but he also says that is only a starting point. u will need to try all 3 to see wich 1 suites YOU best.
as u change pipes u should only see a movement in the torque curve, up or down 600 rpm or so. larger diam will raise the curve.
if u do try dif 1's, record your results with each 1 and please let us know how it works.
u may even have to change your jetting??
That is the sort of testing i would love to undertake.
my problem is the ZRX12 swing arm. it calls for a modified bend.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- saxjonz
- KawboyZ
Re: rs34's
28 Jun 2009 10:19
I agree one hundred percent. If I hadn't of done it to my bike I wouldn't have believed anyone who told me that. I was enjoying riding with the open pipe because of the nice sound and upper end speed and then I put the comp baffle in and woh! What a difference!
79 LTD B3
