rs34's
- martijn
Re: rs34's
23 Sep 2008 12:30
no clacking, running webcams 0.395 at lobes of 104,5 en 108. Gives VERY much torque from 2500-5000rpm. No kick at 9000rpm but will rev 11.000rpm
- mark1122
- Keep twisting it
Re: rs34's
23 Sep 2008 13:17 - 23 Sep 2008 13:44
martijn wrote:
what year/model, was your bike? What carbs?
what size is your baffle,and what pipe are u running?
You said u have pinging in the mid range. what rpm?
do u know how many psi compresion u have?
You should avoide runing to 11000 rpm at all cost.You may get lucky but you could very easily hit a pison with a valve.I did. allthough i do have larger valves and cams.no clacking, running webcams 0.395 at lobes of 104,5 en 108. Gives VERY much torque from 2500-5000rpm. No kick at 9000rpm but will rev 11.000rpm
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 23 Sep 2008 13:44 by mark1122.
- mark1122
- Keep twisting it
Re: rs34's
30 Oct 2008 06:57
I leaned out my carbs a bit ,17.5 pilots air screws at 1/4 turn out instead of 1/2.needles dropped to #2 clip. The slight clacking at idle, and 3000 to 4000 rpm is completely gone now. The plug color looks good but the rpm hangs slightly. If i close the throttle the rpm goes down to idle but not as quick as it should. I’d say that is a lean symptom. Man its hard to read these things. going by plug color just doesn’t seem to be the best way. I wish i had 1 of those Exhaust gas analyzer gauges, Or a Dyno in my garage.
It runs good though. I wont worry about it anymore this year. The cold weather is leaning it out a bit too. My new float needle seats are still leaking a bit. I jut got a new petcock to try and a new sealed tank.
its suposed to be nice out tomorrow . My clutch has been sticking, so i will drain the oil , check my clutch plates and, grease the actuator.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
Re: rs34's
30 Oct 2008 07:43
Sounds like you've got it really close. I haven't even had time to work on mine since I thought I blew the engine!:lol: I'm glad to hear that the clacking can be limited with tuning. That is really annoying me. I'm hoping to synchronize mine and maybe that will help too?
Not sure about the sticking clutch - is the cable and actuator adjusted properly? Is it dragging when you have the lever pulled in? Or do you mean the lever action is sticky, not smoothe?
The Kaw List:
- mark1122
- Keep twisting it
Re: rs34's
30 Oct 2008 08:04
It just started to stick uppon releasing the clutch lever.
What size did u say your baffle was? u could try removeing it just to see how it affects the clacking.i think the baffle size is a big factor here.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
Re: rs34's
30 Oct 2008 08:16
mark1122 wrote:
I forget the baffle size - maybe 1.25"?? - it's the V&H racing version for the megaphone exhausts. I recently drilled some holes internally to increase flow but haven't had a chance to try it yet. Maybe that will make a difference.
So the clutch isn't engaging when you release the lever? It's slipping?
The Kaw List:
- mark1122
- Keep twisting it
Re: rs34's
30 Oct 2008 09:14
The cluch does not release smoothly. It starts to slip smooth, then nothing, then i keep letting it out and it grabs more again. I hope to take it apart tomorrow.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- davel
Re: rs34's
30 Oct 2008 15:04
79MKII wrote:
Have you ported your head? Opening up your intake ports will also make a difference. Bigger intake ports will tend to produce more clacking. Your carbs/engine will not respond too well while the carbs are clacking and the results of switching to a different type of carburettor to get better performance are debatable.
the baffle does make a difference and the racing baffle is a good choice. I also agree with Mark, try running with no baffle just to see what happens.the baffle...it's the V&H racing version for the megaphone exhausts.
- davel
Re: rs34's
30 Oct 2008 15:10
martijn wrote:
Out of curiosity, have you done any porting on this head? If so, what was done? Also, what exhaust are you running? thanks.
- 79MKII
- Love Them Kaws!
Re: rs34's
30 Oct 2008 18:09
The head was professionally ported and totally rebuilt. I just started my bike and it's running terribly. I didn't even try to ride it, just trying to get it to idle. It was pretty dark and I could notice giant flames shooting out of the baffle and it's really popping loudly. Mixture screw adjustments don't seem to make any difference. I also noticed that the #1 exhaust doesn't seem to be as hot as the other 3. I don't know if it's the carbs or a plug, maybe the coils or what - but it ran great the ride before last. I don't get it!!??
Does the popping and flame shooting usually indicate a lean condition?
The Kaw List:
- davel
Re: rs34's
30 Oct 2008 18:26 - 14 Nov 2008 17:02
79MKII wrote:
Sounds like the #1 cylinder isn't firing. Raw fuel is then sent into the exhaust and burned there (ie popping and flames) remove the #1 spark plug. If the porcelin is wet or black, replace it. If not, connect the plug`wire, ground the plug against the block and turn the engine over to see if you have spark.
While you're at it, you might want to pull all the plugs to check their condition.
Definitely do this before you start messing around with any carb adjustments. Also, unlike most other carbs, the RS34s only need a small amount of mixture screw adjustment. start with 1/4 open and don't go past 1/2 turn.
not a lean condition. that would be popping out the intake.Does the popping and flame shooting usually indicate a lean condition?
Last edit: 14 Nov 2008 17:02 by davel.
- 79MKII
- Love Them Kaws!
Re: rs34's
31 Oct 2008 04:48 - 31 Oct 2008 04:49
davel wrote:
Thanks for the tip - that makes sense. I did pull the plugs before I started it and they actually looked pretty good. I pulled #1 after I noticed the pipe wasn't very hot and it was black and wet. I haven't had a chance to check for spark yet, but that will be next. I'll probably change all 4 plugs and try again. I'll also reset my mixture screws to about 1/4 before starting. Maybe it's just a fouled plug?? I hope that's it. Thanks again!
79MKII wrote:not a lean condition. that would be poping out the intake.Does the popping and flame shooting usually indicate a lean condition?
Sounds like the #1 cylinder isn't firing. Raw fuel is then sent into the exhaust and burned there (ie poping and flames) remove the #1 spark plug. If the porcelin is wet or black, replace it. If not, connect the plug`wire, ground the plug against the block and turn the engine over to see if you have spark.
The Kaw List:
Last edit: 31 Oct 2008 04:49 by 79MKII.
