KZ1K'S MOTOR
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: KZ1K'S MOTOR
22 Sep 2010 15:18
#400953
Motor Head wrote:
Good job, very organized. Looks like the rust got at least the valves. Do you have a valve spring compressor?
no, my dad might. we work on bb chevys. if he had one, would it work for the bike?
1978 KZ1000A2
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
Re: KZ1K'S MOTOR
22 Sep 2010 15:20
#400955
likely not, you need a ODHC spring compressor, they can be home made using a big C clamp and socket or piece of abs tubing, I think it is in the tools section. Not expensive to buy though, and you will use it again likely.
  • Motor Head
  • Motor Head's Avatar
Re: KZ1K'S MOTOR
22 Sep 2010 15:21
#400956
Depends on the type he has and if he has a adapter to go into the bucket bore. Ask him what he has first, if he doesn't then it can be taken apart, but probably very hard to reassemble without one.
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 15:27
#400959
dad does not have a valve compressor
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 15:30
#400962
i am a welder/fabricator by trade. you got a link on how to make 1?
or you said they are cheap?
1978 KZ1000A2
  • porchev914
  • porchev914's Avatar
Re: KZ1K'S MOTOR
22 Sep 2010 15:50 - 22 Sep 2010 15:51
#400963
Joe, here is a link to a thread talking about valve spring compressors. If you're a fabber by trade, then this will be a no-brainer. Buy a cheap C-clamp and mod it ;)
kzrider.com/index.php?option=com_kunena&...d=2&id=197012#199088
FRANKEN Z!
Last edit: 22 Sep 2010 15:51 by porchev914.
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 15:56 - 22 Sep 2010 15:57
#400965
very cool. ill get started on that. btw....when the spring is compressed, what do you remove, the half circle pieces? what removes them? thanks ...Joe
also this may sound dumb, but what side does the rubber end go to, the inside or outside?
1978 KZ1000A2
Last edit: 22 Sep 2010 15:57 by kz1k.
  • 9am53
  • 9am53's Avatar
Re: KZ1K'S MOTOR
22 Sep 2010 15:58
#400966
when you compress the springs you can take those little half circle keepers out with a magnet or tweezers. All of this is well explained in the manual along with pics.
  • porchev914
Re: KZ1K'S MOTOR
22 Sep 2010 15:59
#400967
Just like on your dads BBC engines, there are split keepers that fit into grooves at the top of the valve. Compress the retainer and spring to expose the keepers and pull them out with a little magnet. Then when you uncompress the valve spring you can remove the spring retainer and the spring, and the valve will pop out the bottom ;)
FRANKEN Z!
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 16:03 - 22 Sep 2010 16:03
#400968
cant picture it yet, but it will come to me. thanks guys for all your help.
im a lil anxiouse on how much i am going to spend on the motor...i still need lights all around. and some brake parts. oh well...in due time.B)
1978 KZ1000A2
Last edit: 22 Sep 2010 16:03 by kz1k.
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 16:09
#400969
what are the slots for in the socket or pipe? to get the keepers out? and if i use 1" pipe i can just tack weld it to the c clamp?
1978 KZ1000A2
Re: KZ1K'S MOTOR
22 Sep 2010 16:50
#400977
kz1k wrote:
What happened to the chain? :unsure: Ed
