KZ1K'S MOTOR
- DoubleDub
- Visitor
Be very careful hooking up that kind of power to these bikes, in fact, I would get a 12v/2a charger instead.
As before...Harbor Freight is your friend
12v 2/6amp charger: www.harborfreight.com/2-6-amp-6-12-volt-...y-charger-45005.html
Oh, and if you look around, there are almost always 20% off coupons available for Harbor Freight.
- kz1k
- You Cant Fix Stupid!
awesome...thanks:woohoo: . here goes the spending spree..:dry:I'm pretty sure what Ed's trying to say is that the electrical system on these bikes (even though it is 12v) isn't built to handle the amperage of a truck/car battery/alternator system.
1978 KZ1000A2
- PLUMMEN
- Thank you received: 104
- 9am53
- homebrew, and some bbq
- Thank you received: 3
Spending spree? You haven't even done anything yet!!! lol wait till you open the engine up
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- kz1k
see if the parts store has a leak down detector they will rent out
1978 KZ1000A2
- Motor Head
- Thank you received: 391
- testarossa
- Thank you received: 82
when i turn the motor bu kicking the bike i hear air comming from the carbs. i put my hand over them and can feel the air comming out. arent they sopposed to suck air in, not blow air out?
Air being exhausted through the carbs tells me that you have a valve clearance or cam timing issue. No leakdown tester necessary, yet. I would check the cam timing per the service manual first. Then check valve clearances. You are spinning your wheels until you verify those two things.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
I do not believe you would have tight valves on four cylinders at once. I do not believe you would have bad rings on four cylinders at once.
1) However I do believe you could have cam timing issues(past or present). This would account for the low compression.
2) Four sets of slightly bent valves. This can happen from improper cam timing or a broken center pin on the crank.
Who knows? We took an engine(Z1) a part last year, and it had a 410 shot gun shell, inside the cylinder. Crazy stuff has been known to happen.
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- kz1k
1978 KZ1000A2
