KZ1K'S MOTOR
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: KZ1K'S MOTOR
21 Sep 2010 13:13
#400611
what oil should i pour down each sperk plug hole, and how much?
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
21 Sep 2010 13:13
#400612
what oil should i pour down each spark plug hole, and how much?
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
21 Sep 2010 13:22
#400613
when i turn the motor bu kicking the bike i hear air comming from the carbs. i put my hand over them and can feel the air comming out. arent they sopposed to suck air in, not blow air out?
1978 KZ1000A2
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
Re: KZ1K'S MOTOR
21 Sep 2010 13:27
#400616
pour a teaspoon of regular oil in each cylinder.
  • DoubleDub
  • DoubleDub's Avatar
Re: KZ1K'S MOTOR
21 Sep 2010 13:29
#400618
Here is a set of feeler gauges that should work - quite cheap too, if there is a Harbor Freight in your area: www.harborfreight.com/32-piece-sae-metri...ler-gauge-32214.html
A tablespoon or so of motor oil should do it. You are trying to temporarily create a "seal" on the rings of the piston. If the numbers jump significantly when doing this you probably need a rehone/new rings at a minimum. However, I would verify the valve clearances before jumping to any conclusions.
I would do things in this order (but I'm no expert :P )
1. Verify cam timing (if motor was never mucked with, this is unnecessary)
2. Verify cam clearances (using the feeler gauges you are trying to obtain)
3. Compression Test / Oil in chamber compression test.
4. Leak down. A small compressor and an inexpensive leak down set can quickly tell you where most of your compression loss if coming from - my buddy bought this one and it works quite well: www.harborfreight.com/cylinder-leak-down-tester-94190.html
So in conclusion...
The leak down will be the most definitive as to where, but probably not why the compression isn't there.
Adding motor oil to the cylinders will more or less tell you if re-hone and rings are necessary.
But again, if cam timing and valve clearances are off these tests can be misleading.
  • kz1k
Re: KZ1K'S MOTOR
21 Sep 2010 13:37 - 21 Sep 2010 13:42
#400620
So in conclusion...
that helpes me a lot. thank you for taking the time out. i need to get a feeler guage. a compression tester and a leak down. i have a air compressor. thank you, i will do a oil compression test once i grab the tools. as far as i know the timing was never messed with, but im not sure. joe
1978 KZ1000A2
Last edit: 21 Sep 2010 13:42 by kz1k.
  • kz1k
Re: KZ1K'S MOTOR
21 Sep 2010 14:01
#400625
i talked to a friend of mine. he thinks that since all four cylinders are reading low pressure, and my carbs are blowing air out instead of pulling air in, that its a valve stuck open. so i will get a feeler guage and adjust the valves.
1978 KZ1000A2
  • DoubleDub
Re: KZ1K'S MOTOR
21 Sep 2010 14:02
#400626
No problem - as has already probably been stated, a factory service manual, or if not readily available, at minimum a Clymer or Haynes manual would really help. They list most "serviceable" ranges and torque ratings as needed.
  • DoubleDub
Re: KZ1K'S MOTOR
21 Sep 2010 14:05
#400627
I had a compression tested like this one: www.harborfreight.com/flex-drive-compres...tm_source=googlebase
Again, cheap, does the job. For our purposes we aren't going to be doing daily compression tests or need precise measurements...
  • trianglelaguna
  • trianglelaguna's Avatar
Re: KZ1K'S MOTOR
21 Sep 2010 15:17 - 21 Sep 2010 15:33
#400648
(youtube)
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 21 Sep 2010 15:33 by trianglelaguna.
Re: KZ1K'S MOTOR
21 Sep 2010 16:57
#400680
kz1k wrote:
btw my battery is dead in my bike....i need to buy a charger. so i used jumper cables from my truck running, to the bikes battery and cables.
Oh boy, can you say "let's troubleshoot the electrical system next?" ;)
  • kz1k
Re: KZ1K'S MOTOR
21 Sep 2010 17:30
#400687
i dont have a batt charger...it took a shit. :P in due time......joe
1978 KZ1000A2
