KZ1K'S MOTOR
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
Re: KZ1K'S MOTOR
22 Sep 2010 06:11
#400809
I have a different bike, so my procedure is different, but if you look through your manual you will find it for sure. You could also use the search fundtion and try to look it up, OMR has posted the page in question many times.
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: KZ1K'S MOTOR
22 Sep 2010 06:21
#400811
i see the 28 and the in stamped on the back chain sprocket, but where is the T? it sucks when your totally new to this.
1978 KZ1000A2
  • Motor Head
  • Motor Head's Avatar
Re: KZ1K'S MOTOR
22 Sep 2010 06:48 - 22 Sep 2010 07:25
#400816
Same here I have the later chain type of bikes/ info. Have a search this image has been posted like crazy, or 1 of the guys might add it to your thread if you wait. The info would be in your pdf manual, although the pictures might not be real clear.
I sometimes search for stuff with Google, and the link goes back to KZR.
EDIT: Here go to this thread and see if it helps.
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=248585
Last edit: 22 Sep 2010 07:25 by Motor Head.
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 08:02
#400840
yeah i seen that before, and it helps a little. i dont know where the T is and where to start counting and stuff....lemme look at it again.thanks Joe
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 08:06
#400842
yeah i read it again. its super confusing.....lol
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 08:24
#400846
it looks like someone took the time to mark the chain. what is it?
1978 KZ1000A2
  • Motor Head
Re: KZ1K'S MOTOR
22 Sep 2010 08:32 - 22 Sep 2010 08:38
#400849
Probably marked the last time it was assembled. It won't line up with anything now, due to the links in the chain and sprocket sizes, it may take quite a few revolutions to be lined up with where it was then. You need to concentrate on finding the marks on the sprockets and crankshaft. When you put the Crankshaft on TDC, the "T" mark, do you see any of your sprocket marks? If not turn it around again, 360 degrees and see if you can find the cam sprocket marks. The #1 cylinder, the left one, should have both cam lobes facing away from each other, 1 toward the front Ex cam, the other to the rear In cam.
While on the "T", crankshaft mark on advancer, is your valve clearance loose? If the valves were to be bent they would have a lot of clearance. Still on the "T" mark, is the timing chain loose? Pull up on it and see how far it will move, apply a small amount of lifting force, should only show a small, 1/4" maybe of play.
Last edit: 22 Sep 2010 08:38 by Motor Head.
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 08:39
#400850
on the #1, the lobes are facing oposite directions....does that mean its ok?
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 08:50
#400853
is this tdc?
1978 KZ1000A2
  • Motor Head
Re: KZ1K'S MOTOR
22 Sep 2010 09:04
#400856
Thats correct the "T" is TDC and the other marks next to it the 1&4 is right where you need to be to start checking things. Timing is at least close if both lobes are facing away from each other.
Sorry got to run to Denver.
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 09:05
#400857
you mean the lobes on #1 right?
1978 KZ1000A2
  • kz1k
Re: KZ1K'S MOTOR
22 Sep 2010 09:07 - 22 Sep 2010 09:08
#400858
ok...with TDC where it is...1 and 4 are facing front and back, 2 and 3 are facing up and down. what does this tell me? my timing is ok? is it now time to check valve clearence with a feeler guage?
1978 KZ1000A2
Last edit: 22 Sep 2010 09:08 by kz1k.
