KZ1K'S MOTOR
- kz1k
- You Cant Fix Stupid!
21 Sep 2010 09:21 #400555
by kz1k
1978 KZ1000A2
KZ1K'S MOTOR was created by kz1k
hi guys. i was told i had 30-45 psi for compression. now that i have the top off what do i do, or look for?
1978 KZ1000A2
- kz1k
21 Sep 2010 09:22 #400556
by kz1k
1978 KZ1000A2
Replied by kz1k on topic KZ1K'S MOTOR
1978 KZ1000A2
- 9am53
- homebrew, and some bbq
- Thank you received: 3
21 Sep 2010 09:31 #400560
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic KZ1K'S MOTOR
What do you want to do, confirm the compression numbers?
'84 GPz900r
'71 CB350
- Sandy
- Fly High,Tony
- Thank you received: 13
21 Sep 2010 09:35 #400562
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic KZ1K'S MOTOR
First,do another compression test,but make SURE you have the throttle wide open!
From there,you will need to get some feeler-gauges(in the 4 thou inch range)and we will walk you through checking your valve clearances.
What do you have for wrenches?You will need metric wrenches,10mm-17mm......
1977 KZ1000 A-1
- kz1k
21 Sep 2010 09:38 #400563
by kz1k
1978 KZ1000A2
i dont have a compression tester yet. i heard you can rent them at discount, or auto zone? also, lets say the compression is fine....i still wanna clean her up inside. i dont have feeler guages yet either.
1978 KZ1000A2
- kz1k
21 Sep 2010 09:48 #400565
by kz1k
1978 KZ1000A2
ok, auto zone will rent me a compression tester. should i put the top of the motor back on while doing the compression test? also, when i do the compression test i know i have to have the throttle wide open, but what else?
1978 KZ1000A2
- kz1k
21 Sep 2010 10:25 #400569
by kz1k
1978 KZ1000A2
ok i have the compression tester. i am going to test it now.......are these feeler guages ganna work?
1978 KZ1000A2
- kz1k
21 Sep 2010 10:26 - 21 Sep 2010 10:26 #400570
by kz1k
1978 KZ1000A2
1978 KZ1000A2
Last edit: 21 Sep 2010 10:26 by kz1k.
- testarossa
- Thank you received: 82
21 Sep 2010 10:37 #400573
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic KZ1K'S MOTOR
Make sure that your battery is fully charged, and no those feeler gauges are too big. You need the set that usually goes down to 0.0015" thickness. If that set only goes down to 0.010" it's no good for checking valve clearances.
2004 ZX-10R
Angola, IN
- kz1k
21 Sep 2010 10:41 #400574
by kz1k
1978 KZ1000A2
ok with the throttle open #4 jumps up to 90 on the first reading, then after that it only goes up to 45. lemme check the rest.....
1978 KZ1000A2
- kz1k
21 Sep 2010 10:49 #400576
by kz1k
1978 KZ1000A2
ok i have 45-50 psi out of each cylinder. now what?
1978 KZ1000A2
- kz1k
21 Sep 2010 11:03 - 21 Sep 2010 11:06 #400579
by kz1k
1978 KZ1000A2
the compression tester has a button on the side of it to release pressure from the guage. when turned the bike over the meter would go up to 45-50 and then immediatly drop without pressing the button on the side of the compression meter. it would go up to 50 them down to 0, then up to 50, then down to 0. what does this mean? its not holding the compression?
could i have a valve hanging open?
1978 KZ1000A2
Last edit: 21 Sep 2010 11:06 by kz1k.
