- Thank you received: 391
KZ1K'S MOTOR
- Motor Head
There seems to be some confusion as to which term is used for what part of the valve. The margin is important, if to thin the valve will have a tendency to burn, especially the exhaust valves. This is why there is a minimum thickness to be checked after resurfacing the valve "Face", which is the seating/ sealing surface. Also there is a minimum and maximum for this width, along with its mating surface on the seat.
Without the correct tools to do this part of the job, you really need a qualified machine shop. Like I said you may attempt to do the valve lapping at home, BUT you must still use the manual for the seat and valve dimensions, keeping in mind that the job will be a repair and not a rebuild.
- DoubleDub
- Visitor
get everything cleaned up first and measured,then you can decide what parts are needed.
a valve job isnt that big of a deal for a shop that does them all the time,so it shouldnt take that long to get them back.
spend a few bucks after you get the cylinder off and take it and the cleaned up pistons to a bike shop and have the bores and pistons measured before spending money on rings
I agree completely - take a deep breath, get everything inspected/measured. You still don't know for certain why you were losing compression. Better to understand what you have before diving in and spending money - trust me, it will be cheaper in the long run if you inspect/get it all inspected.
And for Pete's sake, give one of the valve job shops a call! They can walk/talk you through everything that's involved/critical with a valve job. And like I said, Larry is probably watching this thread anyways....Larry? Are you there?
- kz1k
- You Cant Fix Stupid!
1978 KZ1000A2
- Motor Head
- kz1k
have the head resurfaced, check valve guides and do a valve job.
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- Thank you received: 797
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- kz1k
My question is, where did all the rust come from? With that amount of rust, a valve job, cylinder hone and new rings is the absolute minimum you should be doing.
i dont know terry. if it was water cooled i would have a guess, but its not. and why was it only 1 cylinder? say it sat in the rain, all the cylinders would have surface rust.
i did a water test to check the valves
results on intake is 2-3 leak water.
on the exzaust its not leaking yet at all....ill give it a few more minutes.
so for sure on the intake 2-3 leak.
1978 KZ1000A2
- kz1k
1978 KZ1000A2
- porchev914
- Thank you received: 19
FRANKEN Z!
- TerryK
Use a solvent like Varsol. Water has too strong a surface tension and won't show leaks well.
Once you know which ones are leaking, disassemble the head and check each valve for obvious signs of being bent. If none are bent, lap the valves. It may be that's all it needs as far as the head goes. Lap ALL the valves, reassemble the whole thing and do the solvent test again.
One thing: do you see any signs of valve to piston contact? Inspect the pistons closely for tiny crescent shaped dimples.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
