KZ1K'S MOTOR
- Sandy
- Fly High,Tony
Re: KZ1K'S MOTOR
23 Sep 2010 10:57
Motor Head wrote:
HA HA HA,you smart-asses.:laugh:
Kidkawie wrote:
:laugh: :laugh: :laugh: :woohoo: :woohoo: :woohoo:
1977 KZ1000 A-1
- Sandy
- Fly High,Tony
Re: KZ1K'S MOTOR
23 Sep 2010 10:59
kz1k wrote:
Well there ya go!
I just wasn't sure of your budget.
Kidkawie wrote:thank you...lol. today has just been super busy, between the phone and kids and kzr..lol.
never seen that 1 before....good 1!
BUT!!! I dont think its ganna work for my heads...if i am leaking water through the valves with no compression......its ganna need more than just that. heads are getting sent out before reassebly period!
if im ganna spent 100 bucks or 2k, im ganna just do it right. whats the point of all that work, then have to go back in sooner than later?
hopefully i can get the heads sent out in the next month. until them i can clean the top end and measure...see what i have and maybe get some new rings in there when ready.
Well there ya go!
1977 KZ1000 A-1
- kz1k
- You Cant Fix Stupid!
Re: KZ1K'S MOTOR
23 Sep 2010 11:03
1978 KZ1000A2
- Motor Head
Re: KZ1K'S MOTOR
23 Sep 2010 11:05
Motor Head wrote:
This was page 6
Have a look at this video, you would be able to attempt this with the parts you have now. But only if they are not in to bad of shape. There are other videos on the side bar and they will show you how, but with tools you don't have to do a valve job.
You need a top end gasket set, not just a base gasket.
You should be able to hone the cylinders and install new rings, but you have to follow the manual for the dimensions for the cylinder, the piston ring lands, etc.
I doubt you will be installing new valve guides at home, if you look at those videos there is a valve guide replacement followed by reaming and then re-cutting the valve seats. All that has to be done if you replace a guide.
This was page 6
- kz1k
Re: KZ1K'S MOTOR
23 Sep 2010 11:12
ill leave it up to larry. im sure he will do me a solid. imo i could do that all day and take the time to put it back, just to pull it apart. i need that reassurance ill get by sending the head to larry.
1978 KZ1000A2
- Sandy
- Fly High,Tony
Re: KZ1K'S MOTOR
23 Sep 2010 11:45
Motor Head wrote:
Totally missed that.:huh:
This was page 6
1977 KZ1000 A-1
- Motor Head
Re: KZ1K'S MOTOR
23 Sep 2010 11:48 - 23 Sep 2010 12:32
Are there any willing members that can go over and help out with this motor work?
He is trying hard but needs some guidance, it can be a bit daunting loosing your KZ virginity!
Here is another video for one of your next steps, honing the cylinders.
AND Another.
AND Another.
Last edit: 23 Sep 2010 12:32 by Motor Head. Reason: Add video's
- kz1k
Re: KZ1K'S MOTOR
23 Sep 2010 13:58
yeah i think i have officially popped my KZ cherry!
1978 KZ1000A2
Re: KZ1K'S MOTOR
23 Sep 2010 14:12
Motor Head wrote:
Nads will soon send over the fat lady.
:laugh:
He is trying hard but needs some guidance, it can be a bit daunting loosing your KZ virginity!....
- kz1k
Re: KZ1K'S MOTOR
23 Sep 2010 14:25 - 23 Sep 2010 14:26
that first video was cool, but my cpu didnt want to run the second video. kept pausing and shit, but i get the idea.
question.....i figure i can hone my cylinders, but if i send my head to larry, is lapping part of the procedure? also when i send him my head is it cheaper to have it disasebled? and when i send the head should i send him my cams, buckets and shims so he can look at them?
1978 KZ1000A2
Last edit: 23 Sep 2010 14:26 by kz1k.
- Motor Head
Re: KZ1K'S MOTOR
23 Sep 2010 14:36
You should really ask him, but I would say that he will want the cams, buckets, and shims. That way he can have all of your head ready for you to bolt on, only needing to re time the cams and crank with the chain. Cheaper, should be 1 set price for a valve job, but the parts that need replacing may add to the total bill.
If you pause the video for a minute or so then push play again, it should run fine.
Get the cylinder off yet? If so look close at the bore where the piston was so rusty looking, #3 i think. It may have quite a rust area where it sat all those years.
- kz1k
Re: KZ1K'S MOTOR
23 Sep 2010 14:42
Motor Head wrote:
no i havnt taken the cylinder off yet,,,been lazy today. after taking my head off yesterday without my roomate, i think he wanted to be there to help. so i told him i would wait for him to take the cylinder off this evening. i did spend a lot of time talking to machine shops and a friend from kzr ...adam on the phone discussing sending my head out, and looking for the idlers, and rubber pillow blocks to look for wear. i also have started a list of things i need to purchase....full gasket set, cam chain, cam chain master link, air filter pods, carb rebuild kit, fuel filters.................
1978 KZ1000A2
