Rear wheel tightening?
- Motor Head
Re: Rear wheel tightening?
22 Sep 2011 11:01
So its the brake rotor hitting the inside of the caliper mounting bracket? Spacers are for sure in the right place? Pretty sure the rotor is flat and not dissed, so I doubt it could be on wrong. You said you had it resurfaced, it would then be thinner, hopefully not below spec. But it shouldn't run into the caliper mount.
Can you take a picture and post it, of the issue and spacing?
- tachrev
- Rubber Side Goes Down
22 Sep 2011 11:04531blackbanshee wrote: tylers right,
johnny's wrong.
I agree.
Comparing this setup to a wheel bearing on a car (as johnny did), is apples to oranges.
Wheel bearings on a car are tapered and must be torqued properly. Just like the steering stem on a bike.
Completely different design.
Build Thread
Build Thread
- Motor Head
22 Sep 2011 12:33
OK I found out why I was having trouble at Kawasaki.com, the 78 KZ1000 is listed under the 1020cc.
Anyway the diagram, right or wrong, is the same as from the other sites. And while the spacers are all listed as discontinued/ canceled, they only fit a narrow range for those earlier models depending on the spacer selected. So looking at the one in my garage won't help out.
I can't tell from the diagram if any of those spacers could be swapped into different positions. But if the #17 bearing in the left side of the wheel hub, is not seated against the longer spacer, then maybe it could be effecting your clearance issue. But I would think it would be very hard, if even possible to get the assy back into the swing arm.
All was OK before new bearings? Did you compare the bearings with the Old ones? Is something miss packaged or otherwise wrong from the kit?
When you sent the rotor out to be resurfaced, it was un-bolted from the hub? They only had the Rotor? Not the Hub and Rotor?
- mvent
22 Sep 2011 12:50
Removed rotor from hub left chain off put back in place and torqued down, spins freely no problem, can't believe it was the rotor,thanks for that suggestion, now I have to get a hold of the person I sent them to, did this almost 9 months ago and just getting it back together, hope it doesn't present a problem, will check front also just in case, unreal.
Thanks to all again, and BTW cranked it down real good(nut bustin good) no binding.
Mike
Mike
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
- Motor Head
22 Sep 2011 12:53
The Rotor is flat, right, not dished? It goes on either direction, or just one way? No way to mix up the front and rear? Different critters?
22 Sep 2011 13:02mvent wrote: Removed rotor from hub left chain off put back in place and torqued down, spins freely no problem, can't believe it was the rotor,thanks for that suggestion, now I have to get a hold of the person I sent them to, did this almost 9 months ago and just getting it back together, hope it doesn't present a problem, will check front also just in case, unreal.
Mike
Glad to hear you found the problem. If the folks who refinished your rotor accidentally swapped it with one from another of their customers, I wonder if the other customer has contacted them? It seems they would have experienced a similar problem. Ed
- T_Dub
22 Sep 2011 13:03 - 22 Sep 2011 13:04
Could it just be the brake pads contacting the rotor causing this? How much resistance to turning do you have? Can't see resurfacing causing it, cause it'd make the rotor narrower, unless its just plain the wrong one.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
Last edit: 22 Sep 2011 13:04 by T_Dub.
- testarossa
22 Sep 2011 13:37
Mike, make sure you don't have your back rotor on the front and vice versa.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Motor Head
22 Sep 2011 14:24
They are certainly different part #'s, although looking quite similar on the drawings. Ending in -005, and -010. Could they be switched around? They don't look flat so Front to Rear would be possible?
- testarossa
22 Sep 2011 15:02
I'm not even sure that they can be switched, but I do remember my stock rotors being remarkably similar from front to rear. If memory serves, the rear rotor was slightly larger in diameter than the front. The thought just popped into my head that if they could be switched, that the offset might be different causing the bind. I would have to go look at the old rotors to compare. Seems that they are in my storage building. Hmmm.....
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- mvent
22 Sep 2011 15:22testarossa wrote: Mike, make sure you don't have your back rotor on the front and vice versa.
This is pretty humbling, but in my haste to get this together, I did have the front rotor on rear :blush: , put the rear rotor on rear and all is well ,front too.
Well I learned not to rush, and that you guys are VERY helpful, maybe someone else will learn from my error.
Thanks again
Mike
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
22 Sep 2011 15:23
glad it worked out for you.
