Rear wheel tightening?
  • T_Dub
  • T_Dub's Avatar
Re: Rear wheel tightening?
22 Sep 2011 15:24
#478648
Great! Main thing is that your problem got fixed! Too bad a war of wills had to happen in your thread, sorry about that.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • Motor Head
  • Motor Head's Avatar
22 Sep 2011 15:49
#478655
Now you'll be able to have confidence in the repair. Also should be able to ride it! That's what makes it all worthwhile. B)
22 Sep 2011 15:58
#478659
Don’t be at all embarrassed! You stuck with it and found and corrected the source of problem instead of using a band-aid solution (like leaving the axle nut loose) that could have resulted in serious problems. I’d call that a win! Glad to hear it’s fixed properly. Ed
  • Old Man Rock
  • Old Man Rock's Avatar
22 Sep 2011 16:32 - 22 Sep 2011 16:33
#478665
Right On! You realized something wasn't correct, researched and successfully figured it out... B)
"Too bad a war of wills had to happen in your thread"... Yeah right T... :whistle: :laugh:
Like we're not an opinionated group here... :pinch: :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 22 Sep 2011 16:33 by Old Man Rock.
  • wireman
  • wireman's Avatar
22 Sep 2011 17:04
#478677
mvent wrote:
testarossa wrote: Mike, make sure you don't have your back rotor on the front and vice versa.
This is pretty humbling, but in my haste to get this together, I did have the front rotor on rear :blush: , put the rear rotor on rear and all is well ,front too.
Well I learned not to rush, and that you guys are VERY helpful, maybe someone else will learn from my error.
Thanks again
Mike
yeah theres quite a bit of differance in the offset between the 2 rotors B)
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
22 Sep 2011 18:39
#478720
glad u got it, and u gained experience, and experience IS the greatest teacher , in spite of what some may say in the PM's :whistle:
I will mention the photo thing again, If u would have posted a photo of the problem area I dare say that would have been spotted right away,
good luck
  • aundershaft
  • aundershaft's Avatar
Re: New guy old post Re: Rear wheel tightening?
20 Oct 2012 10:30
#554834
MY REAR WHEEL WONT ROLL (SAY THAT TEN TIMES FAST)
I've read these threads thru and thru....I have the same problem right now????
I thought it was the recently rebuilt brake caliper..so to take the brakes out of the equation, I removed the pads from the caliper; tightened down the axle nut and the TIRE WONT SPIN FREELY
Now I've read two things...
1. The #19 spacer in between the #17 bearings (6304Z)should have play in it..i.e. not contacting the #17 bearings
2. Says to have the bearings contact the #19 spacer
Which one is it? I am going nuts... :angry: :angry: :woohoo:
On a side note...I bought this 1978 A2 w mag wheels, looks like the front brakes are from a 79. Rear caliper is a dual disc 78 caliper. On another side side note: I recently cleaned out the tank, rebuilt calipers, cleaned out carbs, new tires, plugs etc...Fired it up for the first time
and it runs unbelievably FINE!!!!!! Would roll alot better if the wheel wasn't dragging.
As of now it appears that the #19 inner hub spacer is making contact w/ #17 bearings.
Any help would be appreciated!!! I am so psyched to get this going!!! Now I just want to ride...
Pic is of scoot when I bought it out of a storage locker
20 Oct 2012 11:13
#554840
Think of it in these terms. If you were to tightly clamp the inner race of a motorcycle wheel bearing in a vise it would be stationary but the balls and outer race would still rotate freely around it. When the bearings, spacers, collars, etc. are all properly installed and the axle nut tightened the inner bearing races are stationary but are spaced in a way that no lateral pressure is placed upon the balls. No matter how tight you torque down the axle nut this remains true, so the balls and outer races (plus the attached wheel) will rotate freely. If the wheel will not rotate freely, and if the rear brake has been eliminated from the equation, either the spacers, collars, etc. are not in the proper positions or the bearings are not seated properly in the wheel. Ed
  • aundershaft
20 Oct 2012 11:51
#554847
Ed you are a god...I thank you but I found an answer that no one had (including previous owner). I looked in archives and I found this...
posted on 4-9-2005 at 09:04
Mag wheel models have a washer that goes between the caliper and the spacer,to center the caliper.Get it wroung,the mount can drag on the disc,or cause excessive drag,or even lock up the wheel.
Cyclist Extraordinaire
SOB!!! When I disassembled the rear wheel I put it back in the order I found it...which was WRONG
SO GLAD KZRIDERS was here to HELP!!! To all I thank you!!!!!! Im really happy I didn't beat apart the bearings and wait another week to see whats wrong...YAY!!!!!! I'll keep all uptodate w/ my "barn find". Iz I said in my "new guy" post...1978A2 w/ mags and 3 discs, 9000 miles and runs like a top...I have to address a few minor fixes and it's off to the smoothest highway I can find.
Thanks again Ed and KZ gang... :laugh:
