Rear wheel tightening?
  • mvent
  • mvent's Avatar Topic Author
20 Sep 2011 20:31
#478109
78 KZ1000, have rear wheel centered, chain on, caliper in place, brake arm attached, assembled spacer sequence using manual, must have screwed up because when I tighten castle nut wheel won't spin, what did I do wrong, HELP :angry:
Mike
76 KZ900
76 XLCH
78 KZ1000
04 FLSTFI 120 ci
  • T_Dub
  • T_Dub's Avatar
Re: Rear wheel tightening?
20 Sep 2011 20:38
#478111
No idea, if the spacres are in the right spot it really should spin. Is the bike in gear?
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
20 Sep 2011 21:09
#478131
mvent wrote: 78 KZ1000, have rear wheel centered, chain on, caliper in place, brake arm attached, assembled spacer sequence using manual, must have screwed up because when I tighten castle nut wheel won't spin, what did I do wrong, HELP :angry:
Mike
i HAVE BEEN ADVISED BY A INDY WHO WAS A WRENCH/DEALER for Kawasaki IN THE 70'S ( AND KNOWS these BIKES BACKWARDS AND FORWARDS) TO PAY NO ATTENTION TO THE TORQUE spec, tighten till firm and thats good, worked for me, now the others will slam and advise against, so ...... ur decision
20 Sep 2011 21:16
#478135
Were wheel bearings replaced before reassembly?
20 Sep 2011 21:31
#478145
Check the spacer positions, brake alignment, etc. because you should be able to tighten that castle nut until you pop a hernia and still be able to spin the wheel. Ed
  • P21
  • P21's Avatar
20 Sep 2011 22:09
#478157
can i ask why rear wheel was removed so we have a starting point?
new bearing? how about spacer for inside chain hub?
need alittle info to better help you.
Kawasaki KZ 1000 Police (2002) P21
  • P21
  • P21's Avatar
20 Sep 2011 22:12
#478159
i forgot old age did you leave brake arm loose when tighting wheel and set brake?
  • T_Dub
  • T_Dub's Avatar
20 Sep 2011 22:16
#478162
Mike
When you torque it down you're torquing an assembly of steel spacers and bearing housings, not torquing it has absolutely no advantage whatsoever. I'm sure the guys at Kawi who wrote the service manuals just arbitrarily made up a torque value, knowing that those experienced 1970's american mechanics would figure it out.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • jonnybravo
  • Banned
  • Banned
20 Sep 2011 22:20 - 20 Sep 2011 22:26
#478163
T_Dub wrote:
Mike
see what I told u
when torqued mine to spec the wheel didnt spin freely, when i followed the advice, all was well, thats all I know , go ahead and slam, I could care less
Last edit: 20 Sep 2011 22:26 by Patton.
  • T_Dub
  • T_Dub's Avatar
20 Sep 2011 22:43 - 20 Sep 2011 22:47
#478166
I'm not slamming anyone. If you torque down your wheel and it doesn't spin freely, then theres something the matter that you should take care of. If you don't torque it down the force in the chain that spins the back wheel can pull the wheel towards the engine, slackening the chain, and most likely causing the wheel to go out of alignment. But its up to you. I torque mine down hard and it spins just fine.
I fail to see how disagreeing with you is slaming. I'm not going around personally insulting you or anything.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
Last edit: 20 Sep 2011 22:47 by Patton.
  • RonKZ650
  • RonKZ650's Avatar
21 Sep 2011 00:05
#478179
T_Dub wrote: I'm not slamming anyone. If you torque down your wheel and it doesn't spin freely, then theres something the matter that you should take care of. If you don't torque it down the force in the chain that spins the back wheel can pull the wheel towards the engine, slackening the chain, and most likely causing the wheel to go out of alignment. But its up to you. I torque mine down hard and it spins just fine.
Yea, for the record if torqing the nut has any effect on the wheel spinning freely, stop now and do not ride, because you have assembled something wrong and not safe. Like Ed said, torque to 150ft/lb has no effect whatsoever on the wheel spinning. Stop and figure out what you've done wrong before continue riding.
  • jonnybravo
  • Banned
  • Banned
21 Sep 2011 05:51
#478208
you must be right I'll get right on it :whistle:
