Wiring diagram with munit - REVIEW
- gordone
Re: Wiring diagram with munit - REVIEW
05 Jun 2025 23:28 - 05 Jun 2025 23:28
Yes, the starter turns, but the engine is not turning. There's a "metal noise"—similar to what you hear in cars when the starter isn’t engaging properly with the flywheel.
I’ve heard the same sound a few years ago when the battery was bad. I guess the starter wasn’t spinning fast enough or something like that.
So we are sure that not a bad starter can cause thee issue also... ? The sound was the same... until I replace the battery I remember some years ago.
When I charged the battery up I got typical one chanse to start the engine.. and If I needed a second try than the sound came because the battery voltage was to low...
So, what you're saying is that as long as the starter is turning, the main issue is not with the starter itself, but with the starter clutch?Is it possible that I damaged the starter clutch by pressing the start button quickly—maybe 10–20 times over a few weeks—without letting the starter actually spin the engine properly?The sequence has been:
- Press start button
- Release when the light comes on
Project:
Project:
Last edit: 05 Jun 2025 23:28 by gordone.
06 Jun 2025 00:28
Operating the "start" button to activate your Mo-Unit shouldn't cause any harm (the starter clutch may just of been "on it's last legs") I would start by removing the starter and inspect the gear on it, then poke your finger in the hole and operate the starter clutch by hand (should only rotate one way) and see what it feels like
- gordone
06 Jun 2025 11:48 - 06 Jun 2025 13:02
Took starter out and clean it, I also tried to turn the starter clutch wheel, it just want to turn one way, tried to put som pressure on it, but are only turning one way, guess that is a goid sign, but still problem to engage the clutch looks like…
Tried to push maybe 20 times sudenly the engine started. Stopped and same issue again when tried to start again… so was just lucky seems like.
see video:
streamable.com/8wpyij
see video:
Project:
Project:
Last edit: 06 Jun 2025 13:02 by gordone.
06 Jun 2025 14:35
Try it again with the spark plugs removed (less load on the starter and clutch)
- gordone
07 Jun 2025 03:45
When I took the plug out it turned the engine 9 off 10 times…
I took the plug in and tried to start and I can see the oil pressure liggt blinking and some times disapear when I have the bad sound…
Maybe after 10-15 times the engine started…
I let it run warm. When I try to restart after warm it start much easier… maybe 3-4 attemps…
Project:
Project:
07 Jun 2025 03:50 - 07 Jun 2025 03:52
To be honest it sounds like the starter clutch has failed, looking at the manual you can do this without splitting the cases but it looks quite a job and you will need a "bearing puller"
PS: when it was turning the engine with the plugs out was the noise there ?
Last edit: 07 Jun 2025 03:52 by Wookie58.
- gordone
07 Jun 2025 04:09 - 07 Jun 2025 04:10
No strange sound that I notice just nice rotation sound.
I need to consider what I do… I was ready to start the season now… summer have started in Norway now
maybe only drive small 1-3 hours trips and only park in second gear with hills where I can have a rolling start
so I think it has to be a winter project…
But the job must be smaller to not split the crankcase?
Project:
Project:
Last edit: 07 Jun 2025 04:10 by gordone.
07 Jun 2025 04:21 - 07 Jun 2025 04:25
Yes it's much smaller than splitting the cases, read the section in the manual. You can remove the oil pan and side casing then extract the transmission shaft and drop the starter clutch out of the bottom. If you don't have a suitable "bearing puller" you will need to buy one. The only thing I would say is if the clutch is breaking up there could be debris in there, it's probably a weekends work at most if you have the required gaskets etc ready !!
Last edit: 07 Jun 2025 04:25 by Wookie58.
- gordone
07 Jun 2025 04:59
Ahh, so it can be a risk running like its now without fixing it?
Project:
Project:
07 Jun 2025 09:15Potentially yesAhh, so it can be a risk running like its now without fixing it?
- gordone
08 Jun 2025 09:41
I have created a new thread for the starter clutch repair to not mixing topic more...
z750L: Repair starter clutch - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
Project:
Project:
- Larry G
16 Jun 2025 15:19 - 16 Jun 2025 15:45
Hey I am interested in doing something similar with the m unit and I was going to ask any chance you could put up a few photos of what you have done if possible. I am thinking about doing something similar to you and I was hoping to see what you did and also if you think the motogadget m unit is a good product or would the alternative have been better?
www.louis.de/artikel/axel-joost-joost-el...icle_number=60181030
www.elektronikbox.de/shop/?language=en
This is alot less than the motogadget version. Okay no app but honestly I can live with that.
I am not dissing the motogadget stuff but it's extremely expensive for what it is. I am thinking about looking more into motogadget cause well I am living in Berlin so hopefully they have a showroom or demo at the factory. I tried to call them but no one answered.
I will post on what they say at motogadget.
thank you and sorry to read about the clutch.
Larry
Larry
Last edit: 16 Jun 2025 15:45 by Larry G.
