new to me 1976 KZ 900, wires go where?
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: new to me 1976 KZ 900, wires go where?
22 Dec 2021 12:30 - 22 Dec 2021 12:32
#859489
Run a ground wire from the battery negative post to the engine case
81-KZ440-D2.
LIC, NY
Last edit: 22 Dec 2021 12:32 by F64.
  • rscone11
  • rscone11's Avatar Topic Author
22 Dec 2021 12:30
#859490
Thanks @Mikaw, the color schematic does help.
  • Mikaw
  • Mikaw's Avatar
22 Dec 2021 12:30
#859491
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • Mikaw
  • Mikaw's Avatar
22 Dec 2021 12:31 - 22 Dec 2021 12:32
#859492
Tried to scan not sure is it’s readable.
 If you both pm me your address I can email a pdf copy.
Last edit: 22 Dec 2021 12:32 by Mikaw.
  • Mikaw
  • Mikaw's Avatar
22 Dec 2021 12:48
#859493
rscone11 email sent
  • hardrockminer
  • hardrockminer's Avatar
22 Dec 2021 12:52 - 22 Dec 2021 12:53
#859495
Ok, @F64 thank you for the help.  let me know when to put those wires back together.
I am attaching photos below of the headlight bucket, it's a bit of spaghetti.
It looks like the main blk/yel wire coming into the bucket from the main loom goes to the headlight wiring and a turn signal ground.
In the bottom photo I can see an unplugged plug.  Is that coming from your right control switch?  Why is it unplugged?  Where is the other end?
Last edit: 22 Dec 2021 12:53 by hardrockminer.
  • Mikaw
  • Mikaw's Avatar
22 Dec 2021 12:56
#859496
HRM, this connector in red circle? It’s the turn signal buzzer.
  • rscone11
22 Dec 2021 13:02
#859497
@F64
Ground wire is now run from battery negative terminal to engine case.
Readings are
Red probe + , black probe  to neg - = 11.7v
Red probe on pos and black probe engine case = 11.6v
  • F64
  • F64's Avatar
  • 81-KZ440D2
22 Dec 2021 13:03
#859498
Does your neutral light come on?
81-KZ440-D2.
LIC, NY
  • rscone11
22 Dec 2021 13:09
#859500
@F 64 ,Neutral light comes on
  • F64
  • F64's Avatar
  • 81-KZ440D2
22 Dec 2021 13:13
#859502
Ok,
Reconnect that small black/yellow relay connector.
Take the jumper wire off that connects it to the negative battery post.
Put the big black cable from the starter back on the starter relay terminal.
Try to start the bike.
81-KZ440-D2.
LIC, NY
  • rscone11
22 Dec 2021 13:18
#859503
Ok, done
Ok,
Reconnect that small black/yellow relay connector. check
Take the jumper wire off that connects it to the negative battery post. check
Put the big black cable from the starter back on the starter relay terminal. this has been always connected,
Try to start the bike. nothing
