new to me 1976 KZ 900, wires go where?
  • rscone11
  • rscone11's Avatar Topic Author
Re: new to me 1976 KZ 900, wires go where?
22 Dec 2021 11:09
#859476
@F64, is the wiring in the headlight bucket correct?
  • F64
  • F64's Avatar
  • 81-KZ440D2
22 Dec 2021 11:12 - 22 Dec 2021 11:17
#859477
It looks like a mess but I don't see anything wrong with the headlight wiring.
Duh.
I read it wrong.
The wiring is everywhere.
The taillight has a connector as does the headlight bucket.
Try the headlight first.
81-KZ440-D2.
LIC, NY
Last edit: 22 Dec 2021 11:17 by F64.
  • rscone11
22 Dec 2021 11:18 - 22 Dec 2021 11:19
#859478
@F64
Ok so the black/yellow in the headlight should ground to the turn signal and goes to the headlight.
taillight is currently disconnected.
Last edit: 22 Dec 2021 11:19 by rscone11.
  • rscone11
22 Dec 2021 11:20
#859479
@F64, ok try the headlight yellow/black to check for power?
Key on?
Ignition on?
Light on?
  • F64
  • F64's Avatar
  • 81-KZ440D2
22 Dec 2021 11:21 - 22 Dec 2021 11:25
#859480
Yep
Key on
Ignition on
You want to see 0.0v on the black/yellow.
Red probe on black/yellow in headlight housing
Black probe anywhere on the engine case. Just not on the black/yellow wire.
We want to see if the engine case has a good ground.
81-KZ440-D2.
LIC, NY
Last edit: 22 Dec 2021 11:25 by F64.
The following user(s) said Thank You: rscone11
  • rscone11
22 Dec 2021 11:31
#859481
@Mikaw, F64.
Yes the headlight bucket is a mess, looks like the headlight itself was spliced in, plus lots of other wires with electrical tape. Can I eliminate some of it to try to get the starter working? I currently get the neutral light but no action from the starter when I press start.
Thanks
  • rscone11
22 Dec 2021 11:35
#859482
ok, just saw your note below checking on this.....
  • F64
  • F64's Avatar
  • 81-KZ440D2
22 Dec 2021 11:46
#859484
We'll try to start it in a bit. Not right now.  We need to get your ground wire sorted.
81-KZ440-D2.
LIC, NY
  • rscone11
22 Dec 2021 12:13
#859485
@F64, @Mikaw
The rear black/yellow connector goes to the turn signals, that shows 84v when touching black probe to engine case.
Black/yellow shows 82v at the headlight bucket.
  • Mikaw
  • Mikaw's Avatar
22 Dec 2021 12:22
#859486
Does this help.
  • F64
  • F64's Avatar
  • 81-KZ440D2
22 Dec 2021 12:23
#859487
Key on
Ignition on
Red probe on battery positive post
Black on battery negative post
What is your voltage?
Move black probe to engine case.
81-KZ440-D2.
LIC, NY
  • rscone11
22 Dec 2021 12:28
#859488
results...
Key on
Ignition on, Just FYI,  I notice when I switch the ignition on and off the neutral light dims
What is your voltage?  11.7v
What is your voltage? 116.2v
