Coil Mod
  • otakar
  • otakar's Avatar
Re: Coil Mod
24 May 2010 18:05
#370595
Yes the Accel coils work and mount very nicely, the problem is that you loose about 25% of the spark voltage over the Dyna due to the fact that they are 4 Ohm. The Dyna coils are really great for the J series bikes but they suck for the earlier bikes for mounting and cable arrangement.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • ken
  • ken's Avatar Topic Author
Re: Coil Mod
24 May 2010 18:13
#370598
otakar wrote:
Yes it is the green coils. Plus you will require a set of coil wires. Just remember that the wires are wire kits you will have to crimp and assemble the coil ends. you can PM me about the wires before you buy any.
Ok, I'll start shopping for the dyna s since Z1 is out of stock. Any idea where I should check first?
  • keith1
  • keith1's Avatar
Re: Coil Mod
24 May 2010 18:27
#370599
here is a set of 3ohm accel coils and wires.....3ohm...
www.schnitzracingstore.com/catalogs/cata...28277&showprevnext=1
  • keith1
  • keith1's Avatar
Re: Coil Mod
24 May 2010 18:31 - 24 May 2010 18:34
#370600
dyna s ignition for 3 ohm coils....
www.denniskirk.com/jsp/product_catalog/P...oogle&utm_medium=cse
they are out there....just have to search...good luck....
Last edit: 24 May 2010 18:34 by keith1.
Re: Coil Mod
24 May 2010 19:55 - 24 May 2010 19:56
#370648
ken wrote:
Well I used an ohmmeter and I do have power on the points at the leaf spring when the points are opened.
Continuity test with ohmmeter at points should be done with ignition switch in OFF position.
Good Fortune! :)
Last edit: 24 May 2010 19:56 by Patton.
  • otakar
  • otakar's Avatar
Re: Coil Mod
24 May 2010 20:24
#370658
Just call Z1E and ask them how long they will be out. They are never out very long on anything as long as it is available.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • ken
Re: Coil Mod
24 May 2010 20:47
#370670
Good Fortune! :)
Patton, I did have the kill switch off. It was really wierd. At one point there would be juice on both points, both side while open. I would start her up, turn it back off and then one of the two would have juice while open. Thought maybe there's a a relay or something not opening or closing.
Re: Coil Mod
24 May 2010 21:07
#370673
ken wrote:
Good Fortune! :)
There's not supposed to be any voltage at points while ohmmeter testing for continuity.
If there's voltage at points with ignition switch OFF, then something's wrong with the wiring.
Could detach one battery cable from its terminal to assure no voltage at points while ohmmeter testing for (1) continuity between spring and case with points closed, and (2) no continuity between spring and case with points open.
This will help assure points are doing their job. And that the fiber washers are properly insulating.
Then can separately address whether voltage is reaching points when it's not supposed to.
Good Fortune! :)
  • ken
Re: Coil Mod
24 May 2010 21:24 - 24 May 2010 21:38
#370677
Patton wrote:
ken wrote:
Good Fortune! :)
Good Fortune! :)
I'll try this, after I get a new meter.
Last edit: 24 May 2010 21:38 by ken.
  • ken
Re: Coil Mod
25 May 2010 08:07
#370754
ken wrote:
Patton wrote:
ken wrote:
Good Fortune! :)
Good Fortune! :)
Well, I disconnected the battery/kill switch off and I do have a continuity on one of the points with it opened. I don't think it the fiber washer as the issue moves between points. :dry: Could there be a short in the wiring somewhere? Keep in mind it runs good up to the point the plugs foul.
  • ken
Re: Coil Mod
25 May 2010 08:08
#370755
They told me next week or so.
  • loudhvx
  • loudhvx's Avatar
Re: Coil Mod
25 May 2010 09:02
#370773
The Accel coils are available in 3-ohm. At least the half dozen or so that I have are 3-ohms.
