Coil Mod
  • ken
  • ken's Avatar Topic Author
Re: Coil Mod (wiredgeorge)
21 May 2010 17:46
#369647
Sounds like I should have posted before I purchased the relay and parts. Glad they were cheap!
  • keith1
  • keith1's Avatar
21 May 2010 17:57
#369657
what OMR said......we are not busting your stones....even if you show less than 12 at the coils with bike off and you show a charging rate of say 14.5 at 4k, you should be getting sufficient juice for a decent spark....the connection cleaning will only make things better.....
  • otakar
  • otakar's Avatar
21 May 2010 18:46
#369666
My sincere apologies. Since you are a new guy I should not have started out with this "Not so inside Joke" :blush: But it did get the effect i was hopping for from the old crowd. When you are on this forum a while you will understand it also. At this stage I usually get into trouble with the moderators with my big mouth, so i will let you learn over time since you are now on the right track and have nothing to loose and everything to gain.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • keith1
  • keith1's Avatar
21 May 2010 18:54
#369669
otto,
its all good....the bottom line is another new member will be spared the taste of the "mod kool-aid"....now when he wants his carbs rebuilt, well , all in the know will get
spanked and censored........lol....:laugh:
  • Old Man Rock
  • Old Man Rock's Avatar
21 May 2010 19:00
#369673
And Ken...Uhm, don't get Otto going on oils or engine additives....:huh: :dry: .... :woohoo:
Luv Ya Otto... :kiss: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • otakar
  • otakar's Avatar
21 May 2010 19:01
#369674
Uhhhhhhh- You really know how to get a guy started. :angry: :laugh: :laugh: :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
21 May 2010 19:03
#369675
At least this isn't a gun forum, that's when i really get hummin. :blush: :woohoo: :laugh: :kiss:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • jeffasaki
  • jeffasaki's Avatar
Re: Coil Mod
21 May 2010 19:39 - 22 May 2010 20:11
#369685
Dont do the WG mod.
Hey otto I just picked up a globe 555 mohawk in 303 brit semi auto.Fun gun
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Last edit: 22 May 2010 20:11 by KZQ.
  • bountyhunter
  • bountyhunter's Avatar
Re: Coil Mod
21 May 2010 19:41 - 22 May 2010 19:57
#369686
Old Man Rock wrote:
Out of curiosity...
With out the mod installed, just OEM wiring to the coils through the ignition-kill- switch, with a properly charged and operating battery installed, what is the voltage to the coils?
If +12Vdc or higher with engine running, coil mod isn't going to help you...
Please keep in mind, our jesting at this mod is not directed at you per say... It's been debated to death and in most cases, installed and problem still existed...
Get some voltage measurements and post them and we'll get you on the right track for troubleshooting your problem...
OMR
The point that I make is that if there is significant voltage drop in series with the coil, that V drop is across something and that creates heat by power dissipation. If it is the fuse connector or a harness wire connector with V drop across it and current through it, it is going to get hot and fry which would cause major wiring failure.
Last edit: 22 May 2010 19:57 by KZQ.
  • kawsakiman
  • kawsakiman's Avatar
Re: Coil Mod
21 May 2010 19:49 - 22 May 2010 19:58
#369689
oh oh oh oh oh oh :woohoo:
can i get in on the fun too?
well i really can't.
i've got my pee pee slapped before for saying the same band aid thing before.
but this one should be fun to read.
screw it.:laugh:
i did the coil mod and now i have cops pulling me over because my headlight was too bright and i picked up 100 hp after.
btw, i also have 100 gallons of snake oil you can pour into your tank that will make you able to outrun a zx14
Last edit: 22 May 2010 19:58 by KZQ.
  • larrycavan
  • larrycavan's Avatar
Re: Coil Mod
21 May 2010 19:50 - 22 May 2010 19:59
#369690
These guys were once "mod"
OH...almost forgot...To the originator of this post..none of this is aimed at you. Just having some fun with "mod".
In all seriousness, it's best to just sort out your wiring issues than to band-aid the problem. Will it work? I'll just say this
Last edit: 22 May 2010 19:59 by KZQ.
  • ken
Re: Coil Mod
21 May 2010 20:00 - 22 May 2010 20:35
#369691
Hey Keith,
I have a multi meter. Where do I start? I'm pretty novice with this KZ (electrical stuff). I did all the service on my other bikes, fluid changes, cable adjustment things like that. I'm sure with a little guidiance I can get it running like new.
Last edit: 22 May 2010 20:35 by KZQ.
