Coil Mod
- ken
Coil Mod
21 May 2010 14:55 - 22 May 2010 19:46
After years of my KZ1000 being parked the my garage I"ve got it out and trying "Wiredgeorge's" coil mod. While everything went ok up the the point of powering the coil. George's indstruction say to "Install a blue crimp-on “eye†type connector onto each leg of the “Y†and install these connectors onto one of the two small LUGS on each of the coils. Note that the OTHER wire on each coil will be either black or green" I"m not sure what the LUGS are. I see the green wire and the yellow/red wire comming out of the coil which look to be made in to the coil. I also can see two botls on each end of the coil that attaches them to the frame. Are these bolt the "lugs" the Wiregeorge refers to?
Ths for the help.
Ths for the help.
Last edit: 22 May 2010 19:46 by KZQ.
Re: Coil Mod
21 May 2010 15:13 - 22 May 2010 19:47
Last edit: 22 May 2010 19:47 by KZQ.
- otakar
Re: Coil Mod (BANDAID)
21 May 2010 15:20 - 22 May 2010 19:48
I dont even want to get into another WG coil mod.
You are putting a Bandaid on a bigger problem. Fix it right. Go threw the weiring and clean all the connections That is all it should take.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 22 May 2010 19:48 by otakar.
- ken
Re: Coil Mod (wiredgeorge)
21 May 2010 15:28
Ok Otakar, I'll can try that, but the last time I had it out, about 5 yrs ago, I could only get about 20 mile out of a set of plugs (black soot and fouled). I just finished checking the float level and plan on making a manometer to check the carb balance.
- otakar
21 May 2010 16:07 - 21 May 2010 16:08
First of all what KZ1000 are talking about? Electronic ignition or points? CV carburetors or manual slides? Please give us more info about the bike and more background. also give us more background about yourself.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 May 2010 16:08 by otakar.
- otakar
21 May 2010 16:10
TexasKZ wrote:
Yah- You see it coming, Don't you you Wise-ass. :laugh: :laugh: :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- roy-b-boy-b
- Old Man Rock
21 May 2010 16:34 - 21 May 2010 16:38
Ok, so we have the following:
Coil Mod...
Oil Mod (Rotella)...
Spark Mod...
Ignition Mod...
Fuel Mod (Lucas)...
Chain Mod (530)...
Swing-Arm Mod...
Electrical LED Mod...
And my all time favorite....
Paint Dupli-Color Mod.... :woohoo: :laugh: :laugh:
Coil Mod...
Spark Mod...
Ignition Mod...
Fuel Mod (Lucas)...
Chain Mod (530)...
Swing-Arm Mod...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 21 May 2010 16:38 by Old Man Rock.
- moneypit
21 May 2010 16:45
Old Man Rock wrote:
OMR you forgot fork mod :laugh:
Coil Mod...
Spark Mod...
Ignition Mod...
Fuel Mod (Lucas)...
Chain Mod (530)...
Swing-Arm Mod...
2-76 kz900
St Paul MN
St Paul MN
- ken
21 May 2010 17:08
OK, The bike is a KZ1000A My father-n-law purchased it new in 1977. I got the about 10 yrs ago after he passed away with just over 11,000 mile on it. After I got it I put new tires on it with hopes to ride it to work, about 30 mile each way. The first and only time I rode it to work it left my along side to road. Had to call my wife to bring a new set of plugs. The bike is all stock (points). I've cleaned to carbs, leveled to floats. Just cleaned every connection I could find with steel wool( your advise) put the tank back on. It fire right up and idled fine. I let it warn up good and put my home made manometer on carb 1&2. 2 started to suck hard. So I of course have to get them balanced. It's raining here now, northwest ohio. So I can't take it out to see of the connnection cleaning did the job.
- keith1
21 May 2010 17:32
ditch the mod....like has been said..its only a band-aid....
trace each control harness into main and clean connectors...
pull left side cover and clean all the connectors into that ...make sure battery conns are good....good battery?....buy a 3 dollar multi-meter fron harbor freight
and check charging system......a can of electrical cleaner and an hour or two of labor and you can get back some juice
without the extra wire rats nest the mod involves.....i ll leave my wg comments at the doormat....:blink:
- Old Man Rock
21 May 2010 17:45
Out of curiosity...
With out the mod installed, just OEM wiring to the coils through the ignition-kill- switch, with a properly charged and operating battery installed, what is the voltage to the coils?
If +12Vdc or higher with engine running, coil mod isn't going to help you...
Please keep in mind, our jesting at this mod is not directed at you per say... It's been debated to death and in most cases, installed and problem still existed...
Get some voltage measurements and post them and we'll get you on the right track for troubleshooting your problem...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
