28mm VM carbs
  • Zilla
  • Zilla's Avatar Topic Author
Re: 28mm VM carbs
14 Dec 2019 19:04
#815357
Mikaw wrote: I think we need to be aware of the density of the alternate fluid. If not the same as gas it will affect the buoyancy and maybe not allow proper float adjustment.
I have another bank of carbs to do a float adjustment on and sure would like to use something beside gas again.
Good point didn’t think bout that.
1986 KZ1000P
2005 Vmax
Re: 28mm VM carbs
14 Dec 2019 19:09 - 14 Dec 2019 19:09
#815358
Mikaw wrote: I think we need to be aware of the density of the alternate fluid. If not the same as gas it will affect the buoyancy and maybe not allow proper float adjustment.....
Exactly! The fluid used to set the float height should be the same or very close to the same specific gravity as gasoline. Otherwise the float height will be different when gasoline is used. Ed
Last edit: 14 Dec 2019 19:09 by 650ed.
  • Mikaw
  • Mikaw's Avatar
Re: 28mm VM carbs
14 Dec 2019 19:55
#815361
Found this doing a quick search, the question is how to change the temperature of X fluid to that of gas so we can pick an alternate fluid.
www.engineeringtoolbox.com/specific-gravity-liquids-d_336.html
  • hardrockminer
  • hardrockminer's Avatar
Re: 28mm VM carbs
15 Dec 2019 05:34
#815374
If you're running with ethanol in your gas the SG will be slightly higher than straight gas. (Ethanol has an SG of about 0.79.)
Setting floats is a bit messy. I use a slave tank for supply. I only do two at a time to keep the rack simpler. I also know (with Z1 carbs) that a fully closed float valve means the bottom of the float is about 16 mm below the edge of the carb body. I use that measurement to get the level in the ball park and then adjust as needed to get the right level. I don't bother tightening all 4 screws on the float bowl, as the gas should not rise far enough to leak. One or two screws is usually sufficient.
It's an iterative procedure. Measure, adjust, re-measure, adjust..... My advice would be to use the gas you intend to use for running your bike and wear gloves if the smell of gas is a problem.
  • TexasKZ
  • TexasKZ's Avatar
Re: 28mm VM carbs
15 Dec 2019 06:29
#815378
During a very similar thread a year or three ago, I found a fuel substitute sold for this very purpose. It is non-flammable, and the manufacturer claims the same specific gravity as gasoline . I don't remember if the advertisement said straight, e10, or some other blend. The only drawback I saw was that it is really expensive. No, I don't remember the brand name, nor the website, but a web search should turn turn it up. If you are interested.
As you may have surmised, I use what i normally run in the bike.
  • Zilla
Re: 28mm VM carbs
15 Dec 2019 09:08
#815387
Z1 has pilot jets for the vm28 carb, but is it the 486/ or 213. I want to go from 17.5 to 20. Cause my floats are right, I have 115 main 17.50 pilots needle on third clip but it will not run down the road right it will rev fine but it’s like it’s running out of gas going down the road should I move needle up some more, I’m at a loss.
1986 KZ1000P
2005 Vmax
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: 28mm VM carbs
15 Dec 2019 09:10
#815388
Our shop is in our basement. Besides the potential to stink up the house, there's a standing pilot flame in the water heater, so with gasoline vapor being heavier than air & sinking, that's strong disincentive to adjust floats wet during the winter. We've tried water, kerosene, antifreze amd isopropyl alcohol. None matched the same wet level as gasoline.
We generally do one carb at a time, held level in an old B&D Workmate table vise.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: Mikaw, Zilla
  • Mikaw
  • Mikaw's Avatar
Re: 28mm VM carbs
15 Dec 2019 11:03
#815391
Thanks for the advise, although not what I wanted to here but hopefully I wont have to do to many more wet float adjustments. I have an old briggs 8Hp tractor engine gas tank I set up with a fuel "t" and shutoff to use as a slave tank. I have it mounted on an old halogen light tripod so I can adjust the tanks elevation relative to the bike or the carbs when on the bench. I read the slave tank outlet needs to be a similar distance above the carbs as would be the tank on the bike in full running setup. I read it will affect the fuel pressure and could give inconsistence float level setting if the tank is too high.
Maybe we can revive that post TexasKZ is referencing or start a new one. I don't want to interfere with Zilla's problem solving, Zilla good to here you have the correct float level.
  • hardrockminer
Re: 28mm VM carbs
15 Dec 2019 12:10
#815395
I thought you said in an earlier post that you had 20 pilots. In any case, you might want to hold off on larger pilots until you try the restrictors. I wouldn't go larger than 20 pilots anyway. I once tried 22.5's on my KZ1000 and it bogged down pretty good at lower rpm's. Went back to 20's and had no problems. Not sure what's in them right now....maybe 17.5.
  • Zilla
Re: 28mm VM carbs
15 Dec 2019 14:18
#815397
hardrockminer wrote: I thought you said in an earlier post that you had 20 pilots. In any case, you might want to hold off on larger pilots until you try the restrictors. I wouldn't go larger than 20 pilots anyway. I once tried 22.5's on my KZ1000 and it bogged down pretty good at lower rpm's. Went back to 20's and had no problems. Not sure what's in them right now....maybe 17.5.
Yea I told y’all wrong there’s 17.5 in it, I don’t know why a had 20 on the brain , I guess in the mean time I’m gonna mess with the needle clip I reckon I’ll try the other 4 positions and see what happens, I don’t think the needles are worn out but I did get these carbs off eBay and the seller said (off drag bike) so who knows exactly what needles they are I don’t see any stamps.
1986 KZ1000P
2005 Vmax
  • Zilla
Re: 28mm VM carbs
15 Dec 2019 14:22
#815398
Mikaw wrote: Thanks for the advise, although not what I wanted to here but hopefully I wont have to do to many more wet float adjustments. I have an old briggs 8Hp tractor engine gas tank I set up with a fuel "t" and shutoff to use as a slave tank. I have it mounted on an old halogen light tripod so I can adjust the tanks elevation relative to the bike or the carbs when on the bench. I read the slave tank outlet needs to be a similar distance above the carbs as would be the tank on the bike in full running setup. I read it will affect the fuel pressure and could give inconsistence float level setting if the tank is too high.
Thanks, got that part, but still figuring out why it don’t want to run down the road, it will idle fine and rev fine, I don’t rev it to high but it don’t die or anything when I do. But I come out of first and try and roll on the throttle and it’s like there’s nothing there, I start letting out slowly and it will try and take off but then starts falling off again.
1986 KZ1000P
2005 Vmax
  • Mikaw
  • Mikaw's Avatar
Re: 28mm VM carbs
15 Dec 2019 15:18 - 15 Dec 2019 15:29
#815399
Have you checked the fuel petcock.... is it starving for fuel... I checked Partzilla and your bike originally had a vacuum controlled petcock... Is that still the case... have you checked for good fuel supply???
Last edit: 15 Dec 2019 15:29 by Mikaw.
