28mm VM carbs
- Zilla
Re: 28mm VM carbs
30 Oct 2019 14:32
So the wire will be on the engine side of the carb ? I was thinking it went on the side with the small notch on the slide.
1986 KZ1000P
2005 Vmax
2005 Vmax
Re: 28mm VM carbs
30 Oct 2019 14:46 - 30 Oct 2019 14:55
The small notch on the intake side could be de-formed (out of shape) by the slider pressure if you use a steel wire!!!
This could cause some (high/rough) idle trouble on the pilot Jet jeting air/fuel Ratio.
Last edit: 30 Oct 2019 14:55 by Scirocco.
- Zilla
Re: 28mm VM carbs
30 Oct 2019 15:15Scirocco wrote: The small notch on the intake side could be de-formed (out of shape) by the slider pressure if you use a steel wire!!!
Ok so I’ll stay away from that side, I have some 20ga copper wire that I had left over from a underground dog fence, I think it will work and it’s softer than say electric fence wire.
1986 KZ1000P
2005 Vmax
2005 Vmax
Re: 28mm VM carbs
30 Oct 2019 16:32
I measure from the outlet side, but I don't think it really matters. Copper wire is softer than the slides so it doesn't mark them.
The following user(s) said Thank You: Zilla
Re: 28mm VM carbs
30 Oct 2019 16:47 - 30 Oct 2019 16:51
Copper wire is softer than aluminum and does´t mark them but steel wire does imprints on aluminum!!!!
Anyways later you have to do a vaccum sync after a valve clearence check to get a smoth idle running.
Last edit: 30 Oct 2019 16:51 by Scirocco.
- Zilla
Re: 28mm VM carbs
30 Oct 2019 16:50
Yea I’m gonna use either the copper wire or some plastic pieces I have I use on some rc cars I got
1986 KZ1000P
2005 Vmax
2005 Vmax
- Zilla
Re: 28mm VM carbs
31 Oct 2019 12:32
By any chance any one know the float height in mm I got one over flowing and I don’t have the little screw and tube to check it according to the manual, I was hoping someone would know the measurements off the carb body mating surface
1986 KZ1000P
2005 Vmax
2005 Vmax
Re: 28mm VM carbs
31 Oct 2019 12:40
On Z1 carbs I close the float valve with my finger carefully pressed on the tab and measure the height of the float from the edge of the carb. It's about 16 to 17 mm. That gets me in the ballpark. But not sure if all VM's are the same.
- Zilla
Re: 28mm VM carbs
31 Oct 2019 12:42hardrockminer wrote: On Z1 carbs I close the float valve with my finger carefully pressed on the tab and measure the height of the float from the edge of the carb. It's about 16 to 17 mm. That gets me in the ballpark. But not sure if all VM's are the same.
Ok I’ll try and see , one is wrong now anyway so taking them off and on is unavoidable anyway right lol
1986 KZ1000P
2005 Vmax
2005 Vmax
Re: 28mm VM carbs
31 Oct 2019 17:05
Do it with the floats installed. Just press down on the brass piece directly over top of the float valve. Depress the valve lightly until it's closed and then measure the amount of float sticking above the edge of the carb bowl.
Re: 28mm VM carbs
31 Oct 2019 17:46
If you take a piece of vinyl tubing and grind sort of a pencil point on it you can then screw it into the float bowl threads to make a "clear tube" gauge. That's the best way I've found measure fuel level, not from measuring float height.
The following user(s) said Thank You: Zilla, hardrockminer
- Zilla
Re: 28mm VM carbs
31 Oct 2019 19:24Nessism wrote: If you take a piece of vinyl tubing and grind sort of a pencil point on it you can then screw it into the float bowl threads to make a "clear tube" gauge. That's the best way I've found measure fuel level, not from measuring float height.
How long of a tube, if it’s to long want it give a false reading?
1986 KZ1000P
2005 Vmax
2005 Vmax
