It runs!!!! BUT!
  • ezrider714
  • ezrider714's Avatar
Re: Re:first start after new gaskets plugs and wires
27 Mar 2015 22:57
#665479
bromz wrote: Cam timing is good. So I'm gonna lean towards checking valve clearances and make sure they are within specs. My plugs are dry as a bone and clean as a whistle.
I would definitely check valve clearances
However it sounds to me like clogged/plugged carbs...Been seeing alot of this with todays "gas"
Get a can of starting fluid, spray into air cleaner, then try to start... It should start and run till the starting fluid is used up. Sometimes several runnings will pull the blockage/ clear or at least clear enough to run, to set timing and to attempt a carb synch... The more it runs the higher the chance blockage will be sucked clear......More than likely a good bench cleaning with compressed carb cleaner and verifying passages are open is the minimum that will be needed to be done. There are several good post on this site pertaining to cleaning carbs as to which ports to spray cleaner into to have "fuel" come out the correct ports elsewhere on /in the carb.
Just a guess, easy to try not all so easy to fix really...... The price paid for "progress" :ohmy:
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
28 Mar 2015 05:26
#665487
Yeah carbs aren't the issue. I had them off went through 2 of them then stopped cause they were good and didn't want to risk tearing a bowl gasket
  • bountyhunter
  • bountyhunter's Avatar
28 Mar 2015 13:06 - 28 Mar 2015 13:07
#665557
Then you have carburetor problems.
Compression check will tell you if your valve clearances are OK. No gas is the problem.
Last edit: 28 Mar 2015 13:07 by bountyhunter.
  • bountyhunter
28 Mar 2015 13:11 - 28 Mar 2015 13:11
#665559
bromz wrote: Yeah carbs aren't the issue. I had them off went through 2 of them then stopped cause they were good and didn't want to risk tearing a bowl gasket
I don't know how the carbs could be "good" if they aren't sending enough gas in to show on a spark plug. First thing to do is a clear tube check to make sure the fuel levels are OK. If OK but no gas, your pilots are probably clogged. Could try soaking the carbs with gumout or seafoam liquid by filling them and letting them sit a few days. Then hose down through the fuel inlet with some spray cleaner.
Last edit: 28 Mar 2015 13:11 by bountyhunter.
28 Mar 2015 13:22
#665565
If fitted with the following carb design ---
Good Fortune! :)
  • bromz
  • 1981 kz1000 csr
28 Mar 2015 16:01
#665571
Man the carbs weren't bad and for all carbs to not allow any gas in I'm at a loss
  • bromz
  • 1981 kz1000 csr
29 Mar 2015 15:26
#665651
So checked clearances and all 4 exhaust are tight. 3 with no clearance and one at .03. Three of the intakes are At .05. So everything is tight.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Mar 2015 16:28
#665660
THEY SHOULD'NT BE TIGHT. ADJUST THEM.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Mar 2015 16:33
#665661
That's the problem with shim style valves. New guys don't know how to check and adjust them. They'll run it until a burned valve happens or it won't run. Anything less than .003" is too tight.
  • bromz
  • 1981 kz1000 csr
29 Mar 2015 16:34
#665662
Think that is causing it to not start?
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Mar 2015 16:37
#665663
Definitely. Put your thumb over a spark plug hole and see if you can hold it there while turning it over one cylinder at a time. Poor man's compression tester.
  • bromz
  • 1981 kz1000 csr
29 Mar 2015 16:46
#665665
Ok 3 of the 4 has blowback but #2 zero
