It runs!!!! BUT!
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
It runs!!!! BUT!
27 Mar 2015 09:05 - 19 May 2015 20:35
#665403
Guys the bike turns over nicely, there is fuel to the carb bowls, new air filer, new plugs, new plug wires, spark on all four plugs, could my butterfly's just be closed. I just inspected the carbs but they were ok enough to run the bike and sync them. I tried to start it, a few spits but that is it. drained the battery. I never gave it any throttle so i'm thinking lack of air. any ideas without taking the valve cover back off to make sure I didn't jump a tooth. I haven't strobed the timing yet but this thing should at least start even if it runs a little rough till things get adjusted. Haven't lubed the timing advancer. Should i try some fresh gas and open the throttle a little? till carbs are synced?
Last edit: 19 May 2015 20:35 by bromz.
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: first start after new gaskets plugs and wires
27 Mar 2015 11:17 - 27 Mar 2015 11:18
#665413
bromz wrote: Guys the bike turns over nicely, there is fuel to the carb bowls, new air filer, new plugs, new plug wires, spark on all four plugs, could my butterfly's just be closed. I just inspected the carbs but they were ok enough to run the bike and sync them. I tried to start it, a few spits but that is it. drained the battery. I never gave it any throttle so i'm thinking lack of air. any ideas without taking the valve cover back off to make sure I didn't jump a tooth. I haven't strobed the timing yet but this thing should at least start even if it runs a little rough till things get adjusted. Haven't lubed the timing advancer. Should i try some fresh gas and open the throttle a little? till carbs are synced?
How old is the gas? If it's more than 3 months old it wouldn't hurt. Definitely lube the advance. I thought I had a carb issue and it was really a timing advancer issue. I pulled mine completely apart, cleaned and lubed everything. I used Heavy duty silicone spray to lube mine as it won't collect dirt. After I did that a re-synchronized the carbs and the bike cam alive.
Be very careful not to loose or damage the advancer springs you can't buy them you have to buy the whole advancer.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Last edit: 27 Mar 2015 11:18 by kaw-a-holic. Reason: added content
  • bountyhunter
  • bountyhunter's Avatar
27 Mar 2015 13:32
#665424
bromz wrote: Haven't lubed the timing advancer
If that thing is 180 off, it will never start.
  • bromz
  • 1981 kz1000 csr
Re: Re:first start after new gaskets plugs and wires
27 Mar 2015 14:33
#665436
How do I know? I lines up t 1 4 mark installed camshafts just as the manual said?
27 Mar 2015 14:44
#665438
bromz wrote: How do I know? I lines up t 1 4 mark installed camshafts just as the manual said?
Take a look at the advancer. If it is similar to the one on the KZ650 there will be a mark on the little cam and a hole in the backplate of the advancer. They should approximately line up as shown by the yellow arrows in the image below. If the mark on the cam is 180* away from the hole slip the cam off and turn it 180*. On the KZ650 advancer the cam can only go on either correctly or 180* off. Ed
Attachment AdvancerCloseupwithArrows-2.jpg not found
  • bromz
  • 1981 kz1000 csr
27 Mar 2015 15:52
#665442
My exhaust is sucking air in when trying to start but I lined all marks counted links just as a manual said
  • bromz
  • 1981 kz1000 csr
27 Mar 2015 16:06
#665444
Also my advancer doesn't have the same marks as that one Ed.
  • bromz
  • 1981 kz1000 csr
27 Mar 2015 16:12
#665445
Also I can't confuse camshafts cause on mine the exhaust shaft it has the tach drive gear and I never unbolted the sprockets from the shafts either.
27 Mar 2015 16:41
#665447
bromz wrote: . . . I lined all marks counted links just as a manual said
That's the cam timing, as opposed to the ignition timing.
Hopefully, the advancer has a hash mark that can be positioned as close as possible to a southeast hole when seeing the 1/4 marks through the timing inspection window.
Good Fortune! :)
  • bromz
  • 1981 kz1000 csr
27 Mar 2015 16:46
#665448
So even with exhaust sucking in the pipes at start the cams are ok if aligned as per the manual. And try adjusting the advancer even though I never took it apart ?
27 Mar 2015 18:06 - 27 Mar 2015 18:07
#665453
bromz wrote: So even with exhaust sucking in the pipes at start the cams are ok if aligned as per the manual. And try adjusting the advancer even though I never took it apart ?
With correct cam timing, a descending piston (intake stroke) should suck fuel mixture through the intake valve into the combustion chamber. And a rising piston (exhaust stroke) should push combustion residue out through the exhaust valve.
Although there is some valve opening overlap, am thinking there's not supposed to be any sucking into the combustion chamber through the exhaust valve. Because that would mean the exhaust valve is incorrectly opening when the piston is descending on the intake stroke or power stroke.
Would double-check the cam timing with close adherance to the FSM.
If the advancer itself was not removed and replaced, its orientation would have remained unchanged.
Firing order 1-2-4-3
Good Fortune! :)
Last edit: 27 Mar 2015 18:07 by Patton.
  • bromz
  • 1981 kz1000 csr
27 Mar 2015 18:15
#665454
Cam timing is good. So I'm gonna lean towards checking valve clearances and make sure they are within specs. My plugs are dry as a bone and clean as a whistle.
