Black deposits on pistons
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • KzChop82
  • KzChop82's Avatar Topic Author
Re: Black deposits on pistons
30 Mar 2015 17:00
#665831
So I have everything back together and I'm just about to put the head back on.
I got myself a vesrah complete gasket Kit. Which has been great- except for the fact that it doesn't include the 4 o rings for the stud oil passages (which I don't understand- it has everything else.)
I did wind up have the seats cut by Larry Cabanaugh. Just had a baby- so I didn't have time to work on the bike anyway. Figured it was best to do it while I had everything opened up.
I do have one question though. In the complete best aj gasket kit- it comes with a two piece head gasket kit. The gasket has the metal circles inside the grey fibre.
My question is: what side goes up?
One side of the metal looks like it is been machines flat. The other side looks like the inside corner has been tooled over towards the center of the piston.
The z1 site suggests that the metal side with the wider exposed metal faces up. Problem is- both side of exposed metal are within a couple hundredths of an inch of each other...
What side is up and what side is down?
Attachment image-2.jpg not found
Attachment image-3.jpg not found
Attachment image-4.jpg not found
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
  • KzChop82
30 Mar 2015 17:08
#665833
Attachment image-5.jpg not found
Attachment image-6.jpg not found
Attachment image-7.jpg not found
Attachment image-8.jpg not found
Clinton, NJ
  • KzChop82
30 Mar 2015 17:09
#665834
Larry also refaced all of the valves and relapsed them while he had everything in his shop.
Clinton, NJ
  • KzChop82
03 Apr 2015 16:40 - 03 Apr 2015 17:33
#666446
I have to admit- the viton rubber that comes with the billet end plugs is difficult to deal with.
Hearing the stories about using the rubber- and still having leaks (there is a joke here- but I'm keeping the post PG rated..) I decided I would take a two stage approach. I wanted to use the viton rubber and a sealant (permatex ultra copper).
Attachment ImageUploadedByTapatalk1428103788.990201.jpg not found
But keeping the rubber I place and applying the sealant over the top, and then seating the part inside the head was, to say the least- problematic. So the super glue was used to tack the rubber to the end cap. Then the sealant was applied over top the rubber inserts. The cam cover was then torqued down over the engine to push everything down and will sit over night.
Attachment ImageUploadedByTapatalk1428103970.069418.jpg not found
I'll finish everything tomorrow and report how the dual method worked out!
Clinton, NJ
Last edit: 03 Apr 2015 17:33 by KzChop82.
