Black deposits on pistons
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Re:Black deposits on pistons
09 Jan 2015 12:18
#658187
How'd you have them set them up to 80 PSI?
Chop, those blocks should work. Oak?
  • KzChop82
  • KzChop82's Avatar Topic Author
09 Jan 2015 13:02
#658189
Spanish Cedar, as tough as nails
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • KZB2 650
  • KZB2 650's Avatar
Re: Black deposits on pistons
09 Jan 2015 16:32 - 09 Jan 2015 16:39
#658197
When APE did the head, valve grind, guides, seals, .004 cut, I signed up for the 50 dollar valve spring shimming so they set em up equal and a little less staked I guess.
I talked to Jay before hand too about it and he thought it was a good idea. ( He actually is the one who suggested it). ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 09 Jan 2015 16:39 by KZB2 650. Reason: add remark.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • bluej58
  • bluej58's Avatar
09 Jan 2015 17:33
#658207
KzChop82 wrote: Made these this morning.
Should help to slide the cylinders over the Pistons.
Attachment ImageUploadedByTapatalk1420827567.515948.jpg not found
Clever, please take a pic with them in place
JD
78 KZ1000 A2A
  • KzChop82
09 Jan 2015 18:58
#658212
Will do.
Clinton, NJ
  • KzChop82
09 Jan 2015 19:01
#658213
So here are the seats all cleaned up from 4 to 1
Attachment ImageUploadedByTapatalk1420858561.926731.jpg not found
Attachment ImageUploadedByTapatalk1420858576.192481.jpg not found
Attachment ImageUploadedByTapatalk1420858592.710253.jpg not found
Attachment ImageUploadedByTapatalk1420858611.711568.jpg not found
Clinton, NJ
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jan 2015 21:15
#658223
What about the valves? Course lapping compound should show or take care of the pitting.
  • KzChop82
10 Jan 2015 11:28
#658298
Started the lapping! It's going really well. Getting feel for the noise and vibration from the compound, pickup and move a bit- then continue until the noise and vibration smooths again- then clean and check...
Attachment ImageUploadedByTapatalk1420917810.616263.jpg not found
Attachment ImageUploadedByTapatalk1420917833.733897.jpg not found
Attachment ImageUploadedByTapatalk1420917858.654775.jpg not found
Clinton, NJ
  • KzChop82
10 Jan 2015 11:29
#658299
Razor is just for pointing to the clean ring- couldn't get a good pic. It's super smooth though. Looking good.
Clinton, NJ
  • KzChop82
10 Jan 2015 17:17
#658330
The snap rings on the Pistons- they seem to be in great shape. The service manual says to replace them every time you remove them- has anyone ever re-used them before?
Clinton, NJ
