Black deposits on pistons
- PLUMMEN
Re: Re:Black deposits on pistons
08 Jan 2015 11:00 - 08 Jan 2015 11:11
Last edit: 08 Jan 2015 11:11 by PLUMMEN.
- DobbinsCMA
08 Jan 2015 11:20
Wasn't trying to suggest cranking the cases. Just saying that there is always one more thing that can be done. Didn't mean to offend anyone with my opinion of sending it to a professional to redo the head with shims done as well so all you have to do is bolt the thing back on.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- PLUMMEN
08 Jan 2015 14:02head should torqued down on motor before final shimming of valves.KzChop82 wrote: If I were to send the head out- I have a couple of questions:
A- what would I have to send with it? If they are resetting the shims- wouldn't they need both my cams as well? They would basically need everything but my c chain I suppose?
And B- what does something like that cost?
08 Jan 2015 17:21
- KzChop82
08 Jan 2015 17:28
Rings and valve seals arrived today, along with all new exhaust studs
I will post pictures of the cleaned head as soon as it's done.
Job + 3 year old + pregnant wife = not enough engine time!!
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
08 Jan 2015 17:29DobbinsCMA wrote: Wasn't trying to suggest cranking the cases. Just saying that there is always one more thing that can be done. Didn't mean to offend anyone with my opinion of sending it to a professional to redo the head with shims done as well so all you have to do is bolt the thing back on.
I guess I lost my cool. In my business I've had to deal with engineers that always want to try something else, R&D forever, old timers that won't take suggestions, new people that seem to listen but you can see the wheels spinning in their heads while you are talking to them and owners complaining about how it's taking so long. It happens in every business
If I was too harsh, I apologize.
Steve.
08 Jan 2015 17:35The first one is about what he has. The third one is what they call for in racing. "Pencil" thin. In the real world they turn out like the first. The bike can and will run that way and if the seat is good, the excess width can be ground out.
I'll wait to see how they look before suggesting any more on them.
08 Jan 2015 17:37KzChop82 wrote: Rings and valve seals arrived today, along with all new exhaust studs
The most important things first.
08 Jan 2015 17:41PLUMMEN wrote:head should torqued down on motor before final shimming of valves.KzChop82 wrote: If I were to send the head out- I have a couple of questions:
Yup,That's the way it's done. Believe it or not the tolreances can change.
The following user(s) said Thank You: PLUMMEN
- KzChop82
09 Jan 2015 10:24
Made these this morning.
Should help to slide the cylinders over the Pistons.
Attachment ImageUploadedByTapatalk1420827567.515948.jpg not found
Clinton, NJ
- KZB2 650
09 Jan 2015 11:42swest wrote: I just got off the phone with a Kibblewhite engineer. He told me the 40-1007 springs will not cause premature wear and the titanium retainers are suggested but not necessary for drop in cams. The seating pressure is 90 LBS up from 50 LBS. He said I won't have any problems with them They will send me a statement to this effect to share with others.
I used APE springs on my 650....... I was hoping for 10,000 or just under so I had em set em up at 80lbs 10% less than the normal 90lbs to still control things and yet be a little easier on the valve train.
Might still be a little over kill but then again I might spring for a .365 cam someday.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
