Guess the problem I had get $10.00
- peter1958
- Banned
Re: Cam Timing Issue
16 Apr 2014 16:13
Did you put the exhaust cam in where it should go? and the intake cam where it should?
www.kzzone.com/
- 4TheKZ1000
16 Apr 2014 16:15peter1958 wrote: Did you put the exhaust cam in where it should go? and the intake cam where it should?
yep, went together ok and correctly. Not a mistake during install.......hint
- JimB
Re: Guess the problem I had get $10.00
16 Apr 2014 16:25
forgot the shims
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
16 Apr 2014 16:26
Starter clutch locked up so the starter motor turning over when trying to rotate crank?
- 4TheKZ1000
16 Apr 2014 16:26JimB wrote: forgot the shims
nope, shims are installed
- daveo
16 Apr 2014 16:28
You dropped something in the chain-well that wound up between the chain and the teeth on the front side of the crank, and had to use a magnet to fish it out.
1982 KZ1100-A2
- 4TheKZ1000
16 Apr 2014 16:29Nessism wrote: Starter clutch locked up so the starter motor turning over when trying to rotate crank?
nope, starter is out....starter clutch ok.
- 4TheKZ1000
16 Apr 2014 16:31daveo wrote: You dropped something in the chain-well that wound up between the chain and the teeth on the front side of the crank, and had to use a magnet to fish it out.
great guess, but no.
- daveo
16 Apr 2014 16:33 - 16 Apr 2014 16:33That's it...I'm done :huh:4TheKZ1000 wrote:daveo wrote: You dropped something in the chain-well that wound up between the chain and the teeth on the front side of the crank, and had to use a magnet to fish it out.
1982 KZ1100-A2
Last edit: 16 Apr 2014 16:33 by daveo.
- steell
16 Apr 2014 16:34
Cam sprocket bolts were not tightened?
- 4TheKZ1000
16 Apr 2014 16:35daveo wrote:That's it...I'm done :huh:4TheKZ1000 wrote:daveo wrote: You dropped something in the chain-well that wound up between the chain and the teeth on the front side of the crank, and had to use a magnet to fish it out.
I did it, and it took me some time to find it. Not an easy guess.
- 4TheKZ1000
16 Apr 2014 16:37steell wrote: Cam sprocket bolts were not tightened?
NO.....has aftermarket cams so bolts stay tight, do want to degree them again..
