Guess the problem I had get $10.00
- turboking
Re: Guess the problem I had get $10.00
16 Apr 2014 17:38
top idler did not have correct spacers .......pulled down to bind
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- 4TheKZ1000
16 Apr 2014 17:39JimB wrote: put the cam chain on the outside of the idler versus inside
no, install was correct.
- 4TheKZ1000
16 Apr 2014 17:40turboking wrote: top idler did not have correct spacers .......pulled down to bind
no
- turboking
16 Apr 2014 17:40
cam cover issue?
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- 4TheKZ1000
16 Apr 2014 17:41turboking wrote: cam cover issue?
no
- 4TheKZ1000
16 Apr 2014 17:44 - 16 Apr 2014 17:50
hint......has to do with cam chain a one of the idlers.
its in here
its in here
Attachment diagramb.jpg not found
Last edit: 16 Apr 2014 17:50 by 4TheKZ1000.
- Powerstroke_fan
16 Apr 2014 17:53
forgot to install the spacers on top idler?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
16 Apr 2014 17:54Powerstroke_fan wrote: forgot to install the spacers on top idler?
no
- Powerstroke_fan
16 Apr 2014 17:55
Is it the bolt hitting that holds the slider in?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
16 Apr 2014 17:59Powerstroke_fan wrote: Is it the bolt hitting that holds the slider in?
clarify this for me, more detail
- 4TheKZ1000
- Powerstroke_fan
16 Apr 2014 18:00
its suspose to be a screw that holds the slider in and if you replace it with a bolt or something with a bigger head it will rub
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
