Guess the problem I had get $10.00
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Guess the problem I had get $10.00
16 Apr 2014 16:44
#629288
One more try...the keepers popped loose on the valve.
Nah, no way...good night. :laugh:
1982 KZ1100-A2
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
16 Apr 2014 16:47
#629290
daveo wrote: One more try...the keepers popped loose on the valve.
no and good night..
  • turboking
  • turboking's Avatar
16 Apr 2014 16:55
#629293
cam chain slipped off the crank (to one side) ......clicking is from the cam chain pins on the crank sprocket teeth :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • 4TheKZ1000
16 Apr 2014 16:57
#629294
turboking wrote: cam chain slipped off the crank (to one side) ......clicking is from the cam chain pins on the crank sprocket teeth :S
you paid attention my friend........but NO, try again.
  • turboking
16 Apr 2014 17:05
#629295
cam chain slipped off the side of a toothed idler gear :blink:
1985 GS 1150E
1983 GS 1100E
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Cam Timing Issue
16 Apr 2014 17:07
#629297
the tensioner needs to be installed and snugged before rotating the engine over.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • 4TheKZ1000
16 Apr 2014 17:07
#629298
turboking wrote: cam chain slipped off the side of a toothed idler gear :blink:
no,
  • turboking
16 Apr 2014 17:10
#629299
oil pump not installed correctly
1985 GS 1150E
1983 GS 1100E
  • turboking
16 Apr 2014 17:11
#629300
too long of a bolt in the ignition housing ......rubbing crank
1985 GS 1150E
1983 GS 1100E
  • 4TheKZ1000
16 Apr 2014 17:13
#629301
turboking wrote: oil pump not installed correctly
no
  • 4TheKZ1000
16 Apr 2014 17:15
#629302
Powerstroke_fan wrote: the tensioner needs to be installed and snugged before rotating the engine over.
not the tensioner
  • 4TheKZ1000
16 Apr 2014 17:17 - 16 Apr 2014 17:19
#629303
turboking wrote: too long of a bolt in the ignition housing ......rubbing crank
it can happen, the top rear points cover hole is taped through the case.
Attachment IMG_3842-Copy1222x1600.jpg not found
Last edit: 16 Apr 2014 17:19 by 4TheKZ1000.
